PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 17th May 2015, 04:09 PM   #101
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by tppc View Post
From what I've been able to gather, the AMP+ overlay does not work in 3.18.5 kernel (but is supposed to work in newer, yet to be released kernel) so the /etc/modules drivers must be used instead.
I can code for this in 1.9 but I just want to be sure of your working configuration so if you wouldn't mind confirming the contents of the following files, I'd appreciate it.
(1) /etc/modules
snd_soc_bcm2708
bcm2708_dmaengine
snd_soc_hifiberry_amp
(2) /boot/config.txt
dtoverlay=hifiberry-amp
Have u tested it without the line in #(2) ? Reason I ask is that it's unusual to have both the overlay and the modules loaded at the same time. I'm surprised it even boots like this!
TC
Funny you should ask... I forgot to add it to config.txt and it didn't work, IIRC.
As I mentioned in email, you can see for yourself, if it's easier.
Old 17th May 2015, 10:01 PM   #102
superpat is offline superpat  United Kingdom
Default a good description of hls
HTTP Live Streaming - Wikipedia, the free encyclopedia
Cheers
Patrick
Old 17th May 2015, 11:01 PM   #103
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
I was not able to ssh in today (Network not reachable...), but I see from your email:
"so itís running kernel 3.18.7+ I believe".
I'm guessing that the workaround will not work on 3.18.5 kernel which is current kernel for Moode. Kernel 3.18.7 is in the Feb 16 release of Raspbian so I may try this as new kernel for Moode.
Tim
Old 18th May 2015, 02:37 AM   #104
Skip Pack is offline Skip Pack  United States
Hello Tim,
I have been using your release 1.8 since a few days after you put it out, and am pleased with the advances. The "Library" issue persists, but remains a low priority for me.
I'm posting this to ask about DSD. I see some folks on Computer Audiophile are successfully using DSD128 from USB on the RPi2, which is encouraging to me. Have you tried DSD128 or higher (as opposed to DSD64)? The fellow who reported success was using an NAS and USB out, which I had thought might lead to contention, but apparently not.
Thanks,
Skip
Old 18th May 2015, 06:17 AM   #105
"so it’s running kernel 3.18.7+ I believe".
Tim
I might have given you the wrong details... I just checked it and it works from my us-based server - I will send you a PM.
It is running: 3.18.13-v7+ #784 SMP PREEMPT Sat May 9 15:57:36 BST 2015 armv7l
cat /etc/modules
# HiFiBerry AMP
snd_soc_bcm2708
bcm2708_dmaengine
cat /boot/config.txt
gpu_mem=16
dtparam=i2c_arm=off
hdmi_drive=2
force_turbo=1
Old 19th May 2015, 02:13 AM   #106
I think I've found out why songs get displayed as radio stations - it's when they don't have proper or full tags.
Here - before and after tagging:
Old 19th May 2015, 12:37 PM   #107
TimCurtis's Avatar
Originally Posted by Skip Pack View Post
Hello Tim,
Thanks,
Skip
Hi Skip,
Currently, I don't have any DSD files in my collection to use for testing, but I do have download links to these and other formats. At some point after the need for feature coding dies down, I'll try to focus on format support and plumbing enhancements
TC
Old 19th May 2015, 12:38 PM   #108
TimCurtis's Avatar
The after shot looks much better!
TC
Old 19th May 2015, 10:35 PM   #109
TimCurtis's Avatar
Here's some screen shots of the completed Playback history feature in release 1.9 that includes the following:
- Typedown search
- First/last page speed buttons
- Google song search
The playback history log is turned on/off by a setting on the Custom config popup and cleared if desired, by a setting on the System config page. System logs can also be cleared via System config (no need for ssh!). The history log is maintained by server-side code so no need to have the Player UI running.
tcmods.org
http://twitter.com/MoodeAudio
TC
Old 20th May 2015, 12:01 PM   #110
soundcheck is offline soundcheck  Germany
Hi.
I'm just trying your solution on a Pi2. Worked out of the box. Very nice.
I hooked up my RME Fireface UCX (in class compliant mode).
Another working interface you can add to your DAC list.
A first glance comment:
It seems that just one processor out of 4 is used on the Pi2.
I'd recommend to change CPU affinity and task priority of mpd to e.g. CPU1
and assign the USB interrupt to another free CPU e.g CPU2.
Thx.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
