PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old Today, 02:02 AM   #10051
NuGuy Audio is offline NuGuy Audio
Hi Tim,
I'm a NuBi to all this and giving moode a try in my home made wifi speakers running off rpi3 with a hifi berry amp hat on top. Presently I'm running LMS on my PC as a server and using squeezer to sync my multiple speakers which works great. My problem is when I select internet radio in squeezer it doesn't show anything. What am I'm missing?
Old Today, 02:46 AM   #10052
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by TimCurtis View Post
Hi @gychang,
What I2S driver does the manufacturer specify for this board?
-Tim
They donít...
It uses an NXP UDA1334a chip, which works with the generic/Hifiberry setting.
Cheap DAC... <$0.50 in small quantity...
I use a lot of NXP silicon. Great documentation for their microcontrollers but negligible for their DACs.
Old Today, 04:21 AM   #10053
Blackfear is offline Blackfear
Originally Posted by zek View Post
Hello
"normal" hifiberry-dac driver should works, but seems that these boards has problem with playing 16 bit material...if I were you i will try this one:
ES9038 Q2M DAC DSD Decoder Support IIS DSD 384KHz Coaxial Fiber DOP | eBay
But these are cheap ones so maybe you should count with "some" issuess...
Regards Vita
Old Today, 06:18 AM   #10054
DRONE7 is offline DRONE7  New Zealand
Originally Posted by Blackfear View Post
Hello
Regards Vita
I wondered when this board would get some light...
As Tim has said elsewhere....an MCU on an Ess board that exposes the i2c lines for the hardware volume control and FIR filters would be an interesting workaround.....
DSD64 over coaxial and optical and DSD256 over i2c....
Optical&coaxial input: DSD64 DOP
PCM:44.1KHz,48KHz,88.2KHz,96KHz,
176.4KHz,192KHz,352.8KHz,384KHz
DSD: 2.8 MHz (DSD64) - DoP,native
5.6 MHz (DSD128) - DoP,native
11.2 MHz (DSD256) - native
There is a connector for volume control, One 10K ohm potentiometer can be series connected to adjust volume.
Old Today, 12:19 PM   #10055
rhizomusicosmos is offline rhizomusicosmos  Australia
Default Fix for Hifiberry DAC+ Pro at 352.8 kHz
Hello Tim and Klaus (soundcheck)!
Daniel at Hifiberry has patched the driver for the DAC+ Pro so that 352.8 kHz won't clock at 384 kHz. It appears it has been committed, too:
Fixed a bug when using 352.8kHz sample rate by hifiberry * Pull Request #2231 * raspberrypi/linux * GitHub
Hopefully the kernal update will make it into Moode someday soon
From the snippet of code I saw in the pull request, I don't believe it will break the 384 kHz party for others.
Thanks again,
Richard
Old Today, 01:05 PM   #10056
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi @rhizomusicosmos ,
Good news :-)
moOde 4.0 (December 2017) will have this update along with updated Piano 2.1 driver.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old Today, 05:39 PM   #10057
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
He hopefully also patched the PCM51xx codec to enable 352.8 once and forever
also with the standard kernels! Perhaps you gonna tell him!
It's a very trivial patch - which is available since quite some time.
Old Today, 06:48 PM   #10058
zek is online now zek
Hello
Regards Vita
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright ©1999-2017 diyAudio
