PC Based Computer music servers, crossovers, and equalization
Sound card under .00 US
Old 25th August 2014, 04:15 AM   #1
frabato56 is offline frabato56  United States
Default Sound card under $75.00 US
Hi Nice folks,
My on board sound card just lost a channel and I'm looking for a cheap ($75 US or less) solution. It's mostly used for watching movies. 5.1 surround sound is necessary and I'll be using klipsch f-10's and f-20's. I don't have a subwoofer but maybe I'll add one in the future. The amps are a couple of sonic impact 5066's. I've done a lot of googleing but there is so much out there that I'm just overwhelmed. Truth is that I don't know if I should go pci, pciex1, usb or usb dac. Obviously, for 75 bucks it's not critical but if some of you have any favorites in that price range I'd love to know about them. The 5066's do just fine with the klipsch speakers, I've never turned them even half way up. Looking forward to your recommendations.
Thanks,
Arthur
Old 28th August 2014, 03:42 PM   #2
ppp0001 is offline ppp0001
I would go for cheap audigy 1 or 2 coupled with KX drivers, probably 10$. For movies should be more than enough
Old 28th August 2014, 03:52 PM   #3
shredhead is offline shredhead  United States
shredhead's Avatar
ASUS Xonar DX 7.1 Channels 24-bit 192KHz PCI Express x1 Interface Sound Card - Newegg.com
I had this card at one point and I recommend it. It has a good image and decent dacs.
I would go PCIx1 all the way. When you buy USB you are being charged for knobs, chassis, more jacks, PSU. I'd buy PCIx1 and put all your money into one card's components.
Old 28th August 2014, 06:51 PM   #4
dangus is offline dangus  Canada
You may find a worthwhile PCI card at a computer recycler like Freegeek for five bucks or so. I also found the desirable Live Drive front panel option there (Audigy 2 version, as well as Live).
If the mobo has spdif out, watch out for used Dolby Digital receivers or processors... I've taken home each of those for just $20, though without remotes. If it has hdmi, worthwhile AV receivers can be found new for under $300.
Old 28th August 2014, 07:54 PM   #5
I bought an ASUS Xonar DG. Cheap, as was suggested by ppp0001 and Asus, as suggested by shredhead. ppp0001 also recommended kx drivers. This sent up a red flag because my OS is arch linux but I dual boot with Win 7 and use it for my DAW (notion 5). I had been using the asio4all drivers for lower latency and I am very happy to report that the ASUS Xonar DG actually has it's own asio drivers. Newegg, $17.99 after rebate. I always check new audio stuff by playing "Joe's garage" by Frank Zappa. Not audiophile quality but very, very decent. Surprisingly decent!
Thanks for your responses!
Old 29th August 2014, 01:05 AM   #6
kx should work with both linux and win7 (even 64 bit), but native asio is always better, so good choice!
Old 29th August 2014, 01:26 AM   #7
shredhead's Avatar
I record too and the stock Asus asio will be three times as fast as asio4all
Old 30th August 2014, 04:23 PM   #8
Dangus, thanks for your mention of "Freegeek". I'd never heard of them before but I'm sure I'll find a reason to do business with them in the future.
Old 13th September 2014, 03:25 PM   #9
Logistics is offline Logistics  United States
There's always the trusty, old AV-710 by Chaintech. It has a minor following as well, but being a 7.1 card it's a little more than you need, and likely more expensive than using an Audigy or Live! 5.1 card.
I used to have an SbLive! which I used with the kX drivers, and replaced the decoupling caps between the DSP and output OpAmps with films, and the filter caps along all the power traces with Panasonic FC's, and it sounded fantastic. But I was only going for stereo on the rear channel.
Sound card under .00 USHide this!Advertise here!
WTS (6) Parapix plate amps $75.00 philsaudio Swap Meet 8 16th March 2017 03:13 AM
how to mix sound from notebook and external sound card and get headphones output burence73 Headphone Systems 17 29th December 2012 07:58 PM
Creative Sound Blaster X-Fi sound card w/upgrade GOWA Swap Meet 0 12th August 2012 09:05 PM
For Sale Vintage Magnavox Speakers $75.00 or best offer Sal Brisindi Swap Meet 14 22nd July 2007 07:59 AM
Copyright ©1999-2017 diyAudio
