PC Based Computer music servers, crossovers, and equalization
Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo Quad
Old 16th April 2018, 06:17 AM   #211
phofman is offline phofman  Czech Republic
Originally Posted by sinski View Post
Here they are some latency tests with normal and RT kernel by soundcheck
One would expect the RT kernel to produce lower latency, it is its job. The tests confirm the RT code of the kernel does work, good.
But these tests do not tell anything about audio output quality, only the chain's potential for lower propensity to xruns (which is certainly advantageous).
Old 19th April 2018, 08:58 AM   #212
Moderation Team is offline Moderation Team
Moderation Team's Avatar
Posts not directly related to the thread have been deleted.
Keep the discussion on topic.
Please note: PM's sent to this account will not be answered.
Old 13th May 2018, 09:01 AM   #213
pinkdot is online now pinkdot  Netherlands
Hi Tuxx,
running the latest Alpha release on an RPi 3 --> usb-->Aune S6. Most things work just great. Except Librespot fails to run.
Code:
[root@archphile ~]# systemctl status librespot
● librespot.service - An open source client library for Spotify
   Loaded: loaded (/usr/lib/systemd/system/librespot.service; enabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Sun 2018-05-13 11:39:41 EEST; 36s ago
 Main PID: 650 (code=exited, status=1/FAILURE)
I tried different configs and also my RPi2, but same outcome. Any idea on this issue?
I currently switched to Spotifyd, and used the ARMv6 version. This runs perfectly on both RPi2 and 3.
Code:
[root@archphile ~]# systemctl status spotifyd
● spotifyd.service - A spotify playing daemon
   Loaded: loaded (/etc/systemd/system/spotifyd.service; enabled; vendor preset: disabled)
   Active: active (running) since Tue 2018-04-24 03:32:13 EEST; 2 weeks 5 days ago
     Docs: GitHub - Spotifyd/spotifyd: A spotify daemon
 Main PID: 342 (spotifyd)
    Tasks: 3 (limit: 2302)
   CGroup: /system.slice/spotifyd.service
           └─342 /usr/bin/spotifyd --no-daemon
Thanks,
Martin
Old 14th May 2018, 07:41 AM   #214
tuxx is offline tuxx  Greece
tuxx's Avatar
New packages for ympd are up:
New YMPD packages for 0.99.72 images - Archphile
@pinkdot, please can you paste here all the info that alsacap command gives you?
My Blog!
Read the F*#!ing Manual!
Old 14th May 2018, 11:54 AM   #215
tuxx's Avatar
New MPD 0.20.19 packages are ready for both RPI and Odroid C2:
New MPD 0.20.19 packages for 0.99.72 - Archphile
My Blog!
Old 14th May 2018, 04:40 PM   #216
Rucia1 is offline Rucia1
for Tidal to work it has to start something like that
python /usr/share/upmpdcli/cdplugins/tidal/tidal-app.py
Old 14th May 2018, 04:50 PM   #217
Hi Tuxx,
Here you go:
Code:
[root@archphile ~]# alsacap
*** Scanning for playback devices ***
Card 0, ID `DAC', name `S6 USB DAC'
  Device 0, ID `USB Audio', name `USB Audio', 1 subdevices (1 available)
    2 channels, sampling rate 44100..384000 Hz
    Sample formats: S32_LE, SPECIAL, DSD_U32_BE
      Subdevice 0, name `subdevice #0'
Old 16th May 2018, 10:09 AM   #218
tuxx's Avatar
Hi all,
I am writing to inform you that the first version of the Archphile Manual is up:
Finally! An Archphile manual is up! - Archphile
@pinkdot, please can you double-check with htop to see if you have any running librespot processes?
My Blog!
Old 16th May 2018, 10:57 AM   #219
Hats off, you put a lot of work into the manual. BTW it contains information useful for other projects (e.g. the bit-perfection troubleshooting section).
Old 16th May 2018, 11:09 AM   #220
upmpdcli does not work for tidal
Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo QuadHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
To Raspberry Pi/BeagleBone Black/CuBox/UDOO owners: RuneAudio is looking for testers ACX PC Based 173 10th November 2015 06:44 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
