PC Based Computer music servers, crossovers, and equalization
Inaudible audio
Inaudible audio
Old 15th March 2014, 07:22 AM   #1
BigBrushFilms is offline BigBrushFilms  United Kingdom
Default Inaudible audio
Hi
I am truly stumped....
I have a 'depth bomb' sound effect that is perfectly audible on my MacPro via the external speakers (although it is predominant through the subwoofer). I'm using it on my Final Cut Pro timeline.
If I mix it into the project - to say export the whole project as an MP4 (for example) it is still audible.
HOWEVER, if I play that file on my MacBook Pro or on my television the 'depth bomb' sound effect disappears!
Here is the original file, and I have not initially changed any of the bit rate or sample or frequency settings:
Freesound.org - "DepthBomb_05.aif" by ZeSoundResearchInc.
Type - AIFF (.aiff)
Duration - 00:20:323
Filesize - 6.8 MB
Samplerate - 88200.0 Hz
Bitdepth - 16 bit
Channels - Stereo
Obviously after hours of attempting to get this sound to playback I HAVE tried changing the various options of sample/bit rate (primarily 48 Hz) and frequencies, plus swapped channels, raised/lowered the bass and volume and created different audio file types - AIFF, MP3, WAV, etc. - but no joy. whatsoever.
I've never come across anything like this and I approached a pro sound mixer who is also stumped. It seems the frequency is too low to be heard by all speakers, but I need to find a way to remedy that.
Any ideas? I'd be REALLY GRATEFUL, as this project should be delivered 18th March 2014.
Thank you in advance
Mark
Home - BONOBO
Old 15th March 2014, 11:55 AM   #2
phofman is offline phofman  Czech Republic
Honestly I do not exactly understand the problem, but a question comes to mind - I have heard the LFE channel should get dropped when exporting multichannel to stereo - perhaps something around that?
Old 15th March 2014, 02:21 PM   #3
DF96 is offline DF96  England
If the frequency is too low to be heard through a particular speaker then there are only three options:
1. raise the amplitude - but could damage the amplifier or speaker
2. raise the frequency - will then sound different
3. use a better speaker
Old 26th March 2014, 08:08 PM   #4
CopperTop is offline CopperTop  United Kingdom
4. Generate artificial harmonics..?
The missing fundamental phenomenon is used electronically by some pro audio manufacturers to allow sound systems to seem to produce notes that are lower in pitch than they are capable of reproducing.[21] In a hardware effects unit or a software plugin, a crossover filter is set at a low frequency above which the sound system is capable of safely reproducing tones. Musical signal content above the high-pass part of the crossover filter is sent to the main output which is amplified by the sound system. Low frequency content below the low-pass part of the crossover filter is sent to a circuit where harmonics are synthesized above the low notes. The newly created harmonics are mixed back into the main output to create a perception of the filtered-out low notes.[22]
Missing fundamental - Wikipedia, the free encyclopedia
Edit: A thread on DIYAudio about it
Psychoacoustic bass enhancement
Inaudible audioHide this!Advertise here!
At what point is slew rate performance is inaudible? katana1100 Solid State 4 14th February 2014 02:17 PM
inaudible voice on home theatre system peteski72 Everything Else 11 25th June 2013 01:08 PM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
Transmit 32 bit integer via inaudible high-frequency audio BLoudermilk Construction Tips 4 1st November 2010 11:34 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
