Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 27th February 2014, 08:12 AM   #51
gk7 is offline gk7
Originally Posted by Julf View Post
Sure - if that is what matters to you.
Julf, itīs not about "what matters to me", but about measuring an effect.
I think my question (which was addressed at Pavel who has obviously
extensive experience in measuring such things) was rather clearly stated.
There is no need for you to interpret what "matters to me".
For proper measurements you need at least a spectrum analyzer, but software-based ones are getting pretty good -
Thats why I mentioned ARTA. Sometimes it helps to actually read the posts before responding...
all you need is a low-noise, high-sample-rate sound card/audio interface.
Thats why I mentioned the ADI-2 I use (which is a bit better than the usual sound cards, BTW).
Sometimes it helps ...
Georg
Old 27th February 2014, 08:24 AM   #52
PMA is offline PMA  Europe
PMA's Avatar
Georg,
please check this post
Over sampling of 44.1kHz Wav files.
I have placed it in the 44.1/16 oversampling thread, as it is directly related to the subject there.
Pavel
Pavel Macura
http://web.telecom.cz/macura/audiopage.html
Old 27th February 2014, 08:28 AM   #53
gk7 is offline gk7
Many thanks, that is what I was looking for !
Georg
Old 27th February 2014, 08:31 AM   #54
Julf is offline Julf  Europe
We can measure a zillion different things. Some of them reflect subjectively perceived sound quality, but most of them don't, as long as they are within reasonable limits. Thus it is a question of what matters to you if you choose to care about a difference that might or might not be audible.
Our measurement instruments are great for measuring objective differences, and verifying our designs and models, but in the end it is the subjective sound quality perceived by the listener that is the ultimate "measurement".
"To try to judge the real from the false will always be hard. In this fast-growing art of 'high fidelity' the quackery will bear a solid gilt edge that will fool many people" - Paul W Klipsch, 1953
Old 27th February 2014, 12:56 PM   #55
Default iZotope
Originally Posted by esgigt View Post
Yesterday, searching for software to declip audio, I came upon iZotope RX3 and installed the demo. I fed the program with a beautiful song (clipped) and played around.. after dithering, resampling and declipping (in that order) I got a very good result. The harshness of the clipping had gone, more detail and better soundstage in general.
The problem was $349,- to be able to save this to disc...
There are softwares using iZotope technology at much lower price. Please check this link. Their Sample manager and Triumph use iZotope technology.
Audiofile
Old 5th March 2014, 08:11 PM   #56
Merging Technologies News Story - DXD Captures The Magic of Mahler
Old 5th March 2014, 08:27 PM   #57
eganz1 is offline eganz1  United States
Default Minimum phase filtering using SOX
Okay, I found out how to do the kind of processing I was looking for.
So starting with a 16-bit Redbook CD, I'm using foobar with the SOX plug-in to do the up sampling. I have been up sampling to 88 kHz and 176 kHz at 24 bits FLAC files. In particular, I wanted to compare normal up sampling to minimum phase filters.
The 176 kHz files are huge, and I presume they should be saved for special circumstances. They sound good, but to start with I mostly listened to 88 kHz files. In both cases up sampling in advance seems to be an improvement.
However, the minimum phase upsampling seems better, and seems more musical, and with fewer "digital" artifacts. Of course, we are not achieving SACD quality, but more of the magic seems to be there when using the minimum phase filters.
In particular I set SOX to bandwidth of 90% and minimum phase, with anti-aliasing, and best quality. Apparently, there is an updated plug-in that will allow you to go to 87.5% bandwidth which may be even better.
Eric
Old 5th March 2014, 08:31 PM   #58
Did you try doing just upsampling but staying at 16 bits?
Old 5th March 2014, 09:02 PM   #59
No, I didn't try that, I don't see any reason to restrict ourselves to 16 bits. The methods I'm discussing here obviously require increasing bit depth.
There are plots of the impulse response of these filters here:
Transporter Round Two [SOX] (was Transporter for Ģ999...) - The Hitchhikers Guide To Meridian
In the second half of the page.
These techniques are being used by Meridian and Ayre in their players.
http://www.ayre.com/white_papers/Ayr...hite_Paper.pdf
Old 5th March 2014, 10:26 PM   #60
Wombat is offline Wombat  Germany
Wombat's Avatar
With sox you can't mimic the impulse response of either Meridian nor Ayre. Only some minimum and immediate phase things. I may suggest creating spectral images of these recommended impulse resonses and wonder how much these change the whole frequency behaviour. Better to have the standard pre-echo at frequencies you can't hear.
Edit: i once did some for downsampling with sox but it should illustrate what i mean
If time permits - stuff some parsley in your ears and listen how it grows!
Audio Processing Alan Frobisher Analog Line Level 0 15th June 2013 09:26 PM
Software tool for comparing wav files percy Digital Source 3 25th February 2012 05:27 PM
Need software to convert Alesis DR16 files cloudhopper Digital Source 0 15th April 2010 03:36 PM
Specials on crossover processing software. Could be FREE! Thunau Vendor's Bazaar 0 28th November 2008 02:46 PM
Computer Audio Processing (VxD, WDM and DirectX Audio) Ignite Everything Else 1 3rd August 2001 05:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright Đ1999-2014 diyAudio
