M-Audio Fast Track Pro repair - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 15th January 2014, 07:27 PM   #1
Default M-Audio Fast Track Pro repair
Hello.
I need help in repairing of M-Audio sound card. The model is Fast Track Pro. The problem is highly distorted output. Unfortunately I couldn’t find the schematic. I measured voltages of power supplies pins of opamps. Positive seems ok (4.5V), while negative is only minus 0.8V. I attached the photo. Does the chip which I marked make negative voltage? The marking on the chip is: first line – 67351 or 6735I, second line – 95T, third line – CD8Q. I didn’t find anything on the Internet about this chip. Maybe negative supply is formed somewhere else?
Thanks!
Old 15th January 2014, 07:36 PM   #2
Mooly's Avatar
Just based on what you show it does look like it could be a negative rail generator as there is a coil and diode also shown. Before condemning anything make sure there is no problem on the negative rail that is drawing excess current. The diode itself could be a suspect too.
If you have a bench PSU you could try and backfeed the negative rail in situ with it all working and see if the current consumption is excessive.
Installing and using LTspice IV. From beginner to advanced.
Old 16th January 2014, 07:38 PM   #3
When I connected external negative power supply the card started to work properly. So it seems that the problem is in the part of the positive to negative supply conversion. But I cannot find what is that chip. I searched similar 8 pin convertors but those I watched had different pin location… Maybe someone knows the marking of the chip or proper analogue?
Thanks.
Old 16th January 2014, 07:43 PM   #4
Mooly's Avatar
So that confirms it then. Check that diode and those three electroylitic caps around it. Don't be too hasty to condemn the chip yet.
Old 16th January 2014, 07:51 PM   #5
The diode is ok. Will check those caps.
Old 16th January 2014, 08:05 PM   #6
Mooly's Avatar
The diode is a high speed type and it might not test well in circuit.
Not doubting your readings but you need to sure. Does the chip or diode get warm in use ? Can you measure a supply voltage to the DC convertor chip ?
Old 17th January 2014, 07:17 PM   #7
The diode seems ok. Voltage drop 0.2V. Voltages on the pins: 1 plus 5.57V, 2 plus 1.22V, 3 plus 0.2V, 4 plus 0.8V, 5 minus 0.8V, 8 plus 5.57V. Electrolytic caps are ok. I didn’t removed smd caps for checking but they are less subjected to damage. I watched the pins with oscilloscope – all voltages are constant. The chip and diode are cold.
What do you think my next step should be?
Old 17th January 2014, 07:25 PM   #8
Mooly's Avatar
If the caps and diode seem OK then the next logical step is the problem one... a new chip to try. I'm afraid I don't know what it is either.
Old 17th January 2014, 07:29 PM   #9
Mooly's Avatar
Check out the TI website.
Converter (Integrated Switch) - Inverting Converter - TPS6735 - TI.com
Old 17th January 2014, 07:31 PM   #10
Mooly's Avatar
What is the voltage on pin 1 (chip enable) ?
Fast track or How to utilize two 3-hole chassis for 20W+ monoblocks yagoolar Tubes / Valves 18 10th February 2014 08:49 PM
opinions on m-audio fast track mkII ? tsiros Digital Line Level 0 22nd August 2012 11:43 AM
DBX RTA-M measurement mic,M audio fast track usb. Quick sale tomat Swap Meet 6 21st September 2011 04:09 AM
The 5-minutes Fast Track Pro Stand antomas Construction Tips 14 21st June 2010 02:11 PM
Creative X-Gamer vs M -Audio Fast Track Pro bbluewater PC Based 4 25th April 2010 05:05 AM
Copyright ©1999-2017 diyAudio
