PC Based Computer music servers, crossovers, and equalization
Multi Zone Audio Switch
Old 10th November 2013, 03:48 PM   #1
cabbage is offline cabbage
Default Multi Zone Audio Switch
I am looking to build a multi zone system for my home. I already have a system installed and want to improve on what I already have.
Just to get it out there first my main driver is a low cost tailored solution that meets my needs, I know I could pay the money and get something better but I am doing this to integrate into my Homeseer controlled system and really just to build something useful.
At the minute I have a single amp which feeds 6 zones, I have multiple sources to the amp but I use a home built pic / relay controlled speaker switch to switch zones off and on.
What I want is to use a mini amp per zone and to be able to select the source for each zone and set the volume for each zone.
So I will have say 4 separate inputs, from an FM/ DAB radio source, the HA PC (for Announcements and ITunes interface) and two others I haven't decided on yet.
I want all of this to be selectable from my HA PC so I plan to build a switching/ volume control circuit, I am thinking of using something like the ADG409 for source selection and some digitally controlled pots for volume control, I was looking at something like the ISL22346 as it has I2C for the pic microcontroller.
Obviously I have allot of blanks to fill in which begins with this, if I have 4 common inputs which are switched to 6 different zones with their own line level volume control after the switch and each of which has its own amplifier, do I need some sort of isolation/ amplification of the sources so that when I change the volume switch channels on the various zones I don't distort the signal going to the amplifiers.
Sorry its a bit long winded and feel free to fire any suggestions at me, I am at the early stages of this and appreciate any input.
Multi Zone Audio SwitchHide this!Advertise here!
Multi-Room/Multi-Zone Audio Setup bmk352 PC Based 11 1st June 2015 05:29 AM
Russound CAM6.6 Multi Zone Controller 503Timber Swap Meet 0 10th July 2011 06:11 AM
multi zone speaker hookup willlgord Multi-Way 0 13th December 2010 01:32 PM
Multi zone setup with ATI 6012 neil_kaye Solid State 2 30th September 2010 04:26 AM
Amps for Whole House Audio : Multi-Room : Muilt-Zone Livin Class D 5 5th January 2008 06:59 PM
