PC Based Computer music servers, crossovers, and equalization
Audio server multiple clients
Old 16th September 2013, 07:16 PM   #1
thegreyspark is offline thegreyspark
Default Audio server multiple clients
Hi all,
New to this, so apologies if this is obvious, or asked before, but I can't find a definitive answer.
Is it possible to set up a media server that can serve multiple independent clients? I'm thinking totally within the home so user A on his laptop can listen to one audio stream, and user B somewhere else can listen to something else at the same time?
Is this just a no-no, is it dependent on the particular system, or is it always catered for?
Many thanks
Old 16th September 2013, 08:21 PM   #2
phofman is offline phofman  Czech Republic
Regular network shared drive?
Old 16th September 2013, 08:27 PM   #3
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Multiple network streams at home? Why not use multiple Servers? One for each stream.
Frank
Old 17th September 2013, 08:22 AM   #4
I was thinking more of a classic server/client arrangement. One server, multiple clients. The server is used to take load from the clients, share resources, and provide a similar experience to all clients.
My arrangement would have uPnP devices around the home such as laptops, mobiles, games consoles, accessing a single library of audio content from a server location. The server takes care of things such as library management, content metadata, backups, new clients can just discover the server, browse all the content and play.
Old 17th September 2013, 12:28 PM   #5
i2k92 is offline i2k92  Indonesia
Foobar + upnp server component can handle that. Although I'm not sure how many client it can handle at once
Old 17th September 2013, 03:55 PM   #6
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I had implemented it between pure DOS machines, using NeOS (Network Operating System for DOS) over a coaxial net cable, and the MPXPLAY from PDSoft, and between AMD´s 486's it is working fine from several yeast to this date. Excelent in both MP3 and OGG Vorbis tracks.
First photo is the server; the second, the player.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 24th September 2013, 08:34 AM   #7
thanks for all the responses.
It was easy in the end. Just installed Twonky server, it's a pretty standard application installed on many NAS boxes for the home.
Audio server multiple clientsHide this!Advertise here!
Server power supplies, any good for audio? still4given Power Supplies 14 22nd June 2013 09:31 PM
Using PC as server and storage-replacing NAS DNLA server birdyman PC Based 6 22nd June 2011 09:16 AM
Toughbook laptop as audio server hillbear PC Based 0 4th February 2011 11:10 AM
Digital Audio Music Server kevinkr Digital Source 79 25th June 2008 04:29 PM
The DIY Audio Server subwo1 Everything Else 2 31st December 2003 07:30 PM
