why so complicated player->vsthost->soundcard - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 11th September 2013, 08:01 AM   #1
sraudio is offline sraudio  Lithuania
sraudio's Avatar
Default why so complicated player->vsthost->soundcard
Hello,
Why there is no simple solution(as far as i know) for signal routing foobar-> any vst host ->m-audio 8 channel soundcard. Need to make complex math with stereo signal to make 8channel output. Vst host is perfect for that,vst support in foobar doesn't fit for that. The problem that the only possible way of audio is to send audio to m-audio control panel(spdif out),then back to vst host,then 8ch to m-audi outputs. WHY WHY? ASIO can work only with two devices. But i have three of them.So i have to use direct sound from player to m-audio. Any vsthost i have tried can't take input from player and output to sound card. Using virtual cables or asio or something else. This problem doesn't have people who can use vst inside foobar,then there are no issues like i have. What to use,how to route? I would like not to use direct sound driver in the chain ir it is possible.
Any help very welcome,because i have spend to much time to solve this myself ...
Thanks in advance
Old 11th September 2013, 11:44 AM   #2
phofman is offline phofman  Czech Republic
Did you ask foobar developers at their home forum Hydrogenaudio Forums -> foobar2000 ?
Old 11th September 2013, 01:26 PM   #3
sraudio's Avatar
Didn't ask, but googled a lot. I even can use some other audio player,but the routing principle is the same anyway.
Old 11th September 2013, 01:36 PM   #4
neutron7's Avatar
Have you tried foo_dsp_xover?
Old 11th September 2013, 01:42 PM   #5
That is the place which foobar devs read. IMO the best source for you.
Old 11th September 2013, 01:43 PM   #6
sraudio's Avatar
Yes,but i want flexibility and ability to use plugins which i want.With it's own features.
Old 13th September 2013, 09:08 PM   #7
Use Reaper - it has an ASIO "driver" which routes output from another app into Reaper as an input. Your signal flow looks like
foobar -> ASIO -> Reaper -> soundcard.
Reaper is only quasi-free though. It has a free eval that doesn't expire but has a nagware splash screen.
Old 17th September 2013, 01:56 PM   #8
sraudio's Avatar
Thanks,i will check reaper. Virtual audio cable is almost what i need,just not solved some bugs with that.
Old 14th October 2013, 03:40 PM   #9
Wungun is offline Wungun  Canada
Have you tried J. River media center?
By far, the best I've used when it comes to VST, audio driver, convulsion, etc.
Sent from my iPhone...
Old 14th October 2013, 07:09 PM   #10
Jriver looks like good quality player.
Also tried foobar -> ASIO -> Reaper -> soundcard. This had problem with ugly noise for a second when starting playback of audio file.Temporally i am using sound card audio mixer for rerouting signal to vst host.
May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage Witti Analogue Source 17 31st May 2013 04:57 AM
M-Audio Transit =>>I2S =>> PCM1794 schultzsch Digital Line Level 1 15th November 2012 06:25 PM
>> WTB: TDA1541A-S2 Taiwan made >> zeroalbedo Swap Meet 15 9th August 2012 05:34 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 05:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 04:36 PM
Copyright 1999-2017 diyAudio
