PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 18th July 2018, 07:52 PM   #3001
Triplefun is offline Triplefun  New Zealand
Originally Posted by dcadams View Post
After upgrading from 17.09 (daphile-17.09-x86_64.iso) to 18.07 (daphile-18.07-x86_64.iso) my network drive is no longer connecting.
With 17.09 all was ok. If I downgrade back to 17.09 the drive reconnects. Each time I try 18.07 it doesn't connect.
My drive params are:
cifs://
Remote Target: 192.168.0.1/Music
Password: None
Usage: Music
RW: ticked
Identification: MusicLibrary
The drive is directly off the router.
Anyone have a similar issue or a similar configuration that works with 18.07?
Have you checked the log files to see what the difference is?
I listen, therefore I am !
Old 19th July 2018, 01:45 AM   #3002
dcadams is offline dcadams
Thank you for the reply.
I did look briefly at the logs under "Info" but nothing jumped out. I could take another look.
I believe the issue would be on system startup and network connecting so the Media Server log may not be all that useful. Are there other logs available with the output from initial startup?
Old 27th July 2018, 06:54 AM   #3003
adamlam is offline adamlam
Anyone seeing a performance degradation for the latest version (18.07)?
I ask since it includes fixes for Meltdown and Specter.
Yes maybe the attenuation had up to -7db from -1db
Old 1st August 2018, 09:52 AM   #3004
mannaro is offline mannaro  Italy
Default No more Radio?
Hello everybody, after the last upgrade (non beta) I can't hear radio no more. The radio button on the tree list on the left now asks for an URL instead of listing the available stations. I had saved some in my favorites list, but when I click on them I can't hear nothing though the time counting runs. Now and then, when I browse Daphile with my tablet, a dark screen appears with a "play" button. If I click it I hear music on the tablet (!). Any suggestions? (including switch back to previous version). Thanks
Old 5th August 2018, 10:36 PM   #3005
Hi to all those Gustard X20 owners. I recently procured a Singxer SU-1 and upgraded the firmware to 2.22. Then played back through the latest Daphile Beta and realised DSD512 playback with NO HISS. And to my ears there is a noticeable improvement to DSD256.
Old 6th August 2018, 06:46 PM   #3006
curentatu is offline curentatu
Can someone explain to me what each buffer does?
Stream Buffer --- ?
Output Buffer --- ?
Alsa Buffer Time --- ?
Alsa Period Count --- ?
@Triplefun I also get a pulsating hiss when using DSD512 on my Audio-Gd NFB28
Old 6th August 2018, 07:52 PM   #3007
I was wrong. After several restarts there is now an initial noise when playing the first track. Fortunately it then disappears for the remainder of the listening session. This is using a gustard x20u (no electrical mods), singer su-1, and daphile with all music, other than DSD, being upsampled to dsd512.
Old 6th August 2018, 07:53 PM   #3008
The radio still works for me when using the latest beta but not all stations. I have not experienced the tablet 'dark screen'. Try loading the beta.
Old 8th August 2018, 12:42 PM   #3009
PSSO is offline PSSO  Denmark
Originally Posted by Tromperie View Post
Every PC I've ever used has an option to disable the internal audio in BIOS.
Have you checked in the BIOS?
I have a Mitac PD10RI MT motherboard and it don't have any option for disabling Audio in the BIOS (only an option for disabling "Front Panel Audio")
So to keep Daphile from loading the driver for the Intel sound card, I have "blacklisted" the driver.
- log in as root (beta version of Daphile)
- nano /etc/modprobe.d/sound.blacklist.conf
- add the following entry to the file and then save and close it:
- blacklist snd_hda_intel
Does anyone have a better suggestion ?
Old 9th August 2018, 07:41 AM   #3010
DRONE7 is offline DRONE7  New Zealand
Does that not achieve the same end.... ? Did you try it ?
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
