PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 11th July 2018, 11:18 AM   #2991
adamlam is offline adamlam
Originally Posted by adamlam View Post
Yes it no sound after 30min but the player is running only no output to the dac
May be the size of the WAV file too big for my computer, it only have 4G ram
Old 11th July 2018, 11:44 AM   #2992
Julf is offline Julf  Europe
A whole album only takes 0.6 G (at 44.1/16).
Old 11th July 2018, 02:28 PM   #2993
Yes, not about the size of the momory. I just try run the same WAE file with a 2.4G zh 8G ram, same result handed
Old 11th July 2018, 10:25 PM   #2994
Triplefun is offline Triplefun  New Zealand
FYI, I have used the latest beta to play a 180MB wav file upsampled to dsd512 using 1.6GB RAM and just over 50% utilisation of my i7 7700. Please look at your log files ..
Go to the info tab and view the log files for the scanner, sever, and DAC transcode
I listen, therefore I am !
Old 12th July 2018, 12:03 AM   #2995
let me try it later. But my WAV file is 500MB something
Old 12th July 2018, 01:01 AM   #2996
I found a .wav file 1.2GB and had no issues with DSD512.
Old 15th July 2018, 04:17 PM   #2997
dcadams is offline dcadams
Default Performance of 18.07
Anyone seeing a performance degradation for the latest version (18.07)?
I ask since it includes fixes for Meltdown and Specter.
Old 15th July 2018, 10:29 PM   #2998
Tromperie is offline Tromperie  Australia
No.
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 16th July 2018, 09:37 AM   #2999
SkipSpence is offline SkipSpence
2018-03-17 beta version 18.03-b170939 (x86_64-rt) remains the stablest to me so far.
Since "Web UI improved for Daphile client connected to external Daphile server" feature in 18.04-b291019 was introduced, there is no playing stability (glitches, hickups, system overload) in all following versions, including this latest one, playing all by convertion to DSD256 using 2PC-setup: server-player.
Old 16th July 2018, 06:16 PM   #3000
Default cifs drive not connecting with 18.07
After upgrading from 17.09 (daphile-17.09-x86_64.iso) to 18.07 (daphile-18.07-x86_64.iso) my network drive is no longer connecting.
With 17.09 all was ok. If I downgrade back to 17.09 the drive reconnects. Each time I try 18.07 it doesn't connect.
My drive params are:
cifs://
Remote Target: 192.168.0.1/Music
Password: None
Usage: Music
RW: ticked
Identification: MusicLibrary
The drive is directly off the router.
Anyone have a similar issue or a similar configuration that works with 18.07?
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Resources saved on this page: MySQL 66.67% / PHP 65.06%
