PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 14th August 2013, 09:14 AM   #21
soundcheck is offline soundcheck  Germany
Hi.
Interesting project. I'll give it a try.
Though I'm wondering what the term "Audiophile" means in the context of Daphile!?!?
How about squeezelite support instead of squeezeplay??
Is there a way to just configure a basic player installation of Daphile without all the server, ripping, asf functionality.
That would deliver a nice server/client networking solution.
As far as I understand Daphile currently acts the same way as MPD. It's basically a local server and player. Please correct me, if I'm wrong.
Cheers
Old 14th August 2013, 06:37 PM   #22
kurt10 is offline kurt10  Antigua
Daphile is great...
Please releases a 32 bit version..
Old 15th August 2013, 11:15 AM   #23
Kipeta is offline Kipeta  Finland
This is what I answered to the same question at the hydrogenaudio forum:
First of all Daphile is “only” software (familiar comment from HW guys ;-) so I limit the answer to that scope. If a software solution is capable of giving the bitperfect and gapless playback stream (without disruptions or at least very minimal) to hardware using the audiophile class input file formats then I would say that software is completely neutral in respect to audio playback quality. And that would be my main criteria for 'audiophile class' qualification.
I later commented about 'audiophile class input file formats' the following (for question: what are these?):
The best that's available. Lossless format with different sampling rates and sample sizes. Minimum CD quality 44.1kHz 16bit. Different container formats: flac, wav, aiff, wv, ... (DRM free). Daphile does not support everything. DSD formats are still missing - I'll try to work on that.
I have tried but had some problems (one related to minor audio glitches in some situations, don't remember exactly anymore). Squeezeplay (that I have patched a little bit) just performed better. I haven't checked the latest Squeezelite version but I currently I don't see any problems with Squeezeplay and no reason to swap.
You can use Daphile also as a player client for existing server. At least the local media server and file server can disabled. I don't remember the CD ripping (you can ignore it).
Old 15th August 2013, 11:21 AM   #24
Originally Posted by kurt10 View Post
Daphile is great...
Thanks for your feedback.
I currently focus on getting the basic functionality developed with x86_64 and I don't want split my limited resources on supporting multiple platforms.
I'll reconsider to broaden platform support later.
Old 17th August 2013, 09:26 AM   #25
New test release available at www.daphile.com!
CHANGES on August 17th 2013:
  • Initial DSD file support:
    • DSF (.dsf) and DSDIFF (.dff) supported (both DSD64 and DSD128)
    • no native DSD-over-USB (DoP) yet. Coming soon - have to get DAC with DoP support.
    • no support for DST compressed files (didn't find any samples)
    • Known issue: "Clear library and rescan everything" rescan does not include DSD files. "Look for new and changed audio files" rescan works.
  • Linux kernel upgrade from 3.6 to 3.8 series.
Old 21st August 2013, 03:09 PM   #26
Default New test release available!
CHANGES on August 21st 2013:
  • Support for native DSD playback with DSD-over-PCM (verified only for DSD64 with Benchmark DAC2 HGC). Enable it from Audio Settings for the DAC that supports it.
  • DSD file "Clear library and rescan everything" problem fixed
  • Replay Gain calculation added to the CD ripping process
  • Some other minor bug fixes and changes
Update via your Daphile web UI or download from www.daphile.com.
Any feedback is warmly welcomed! Now especially any DSD-over-PCM experiences with different DACs and DSD128.
Old 28th August 2013, 03:48 PM   #27
CHANGES on August 28th 2013:
  • Bug fix release - no new features
  • Wireless networking fixes: recover from initial scan failure, simultaneous client/hotspot operation fixed
  • Sound format conversions improved for different audio devices (use plughw as fallback)
  • Some other bug fixes and minor changes
Old 2nd September 2013, 02:49 PM   #28
realmadrid is offline realmadrid  Sweden
Hi Kipeta:
Daphile lose the track when going to different sampling frequency.
Need to restart.
Now i cant stop listen Beethoven for All- Barenboim & WEDO @24/192... 9 hours!!!...
(after restart). The music IS wonderful.
And no SSH2 service?
CryptoTerm shows:
Connection error occurred
Code: 10061
Server is not available
Thanks for your gift.
Juan.
Old 2nd September 2013, 09:02 PM   #29
Originally Posted by realmadrid View Post
Hi Kipeta:
Need to restart.
CryptoTerm shows:
Code: 10061
Juan.
Daphile does not have ssh server enabled.
Could describe the sampling frequency change problem in detail? What DAC are you using? Is the problem somehow repeatable?
Old 5th September 2013, 10:47 AM   #30
pietjers is offline pietjers  Netherlands
pietjers's Avatar
Daphile looks very interesting for a Linux newbies (like me), but with best possible soundquality in mind, has anyone already compared Daphile for soundquality with other Linux distributions? Could someone please comment on this issue?
Peter
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
