PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 13th January 2014, 08:51 AM   #281
Tyimo is offline Tyimo  Hungary
Thanks!
I tried also the Squeezer and it works, but I cann't open my "musicfolders" (the harddisk). It is showing "loading", but do nothing. How many time need to scan my folders?
Old 13th January 2014, 09:15 AM   #282
tilroh is offline tilroh  Australia
Originally Posted by Tyimo View Post
Thanks!
Seems like it takes about 30min for 400GB.
Old 13th January 2014, 10:16 AM   #283
Eudyptes is offline Eudyptes  United Kingdom
Hi Kipeta,
A little feedback on my use so far of Daphile:
Under “General” the purpose of the “Media Server” input box and radio buttons is not clear. Does the label “Media Server” apply to LMS which is as the heart of Daphile, or does is apply to the Daphile as a whole? What is the effect of entering an IP address in this input box?
There are some slight inconsistencies of naming in the Daphile UI. Under “AudioPlayer > Music Folders” we have drives, under “Storages” we have drives, but under “System Firmware” we have “set target disk” etc. I would suggest changing this to “set target drive” and use “empty drive ...” and “drive containing ...” in the other text.
Under “CD Ripper”, when does the term “disk” mean a drive, and when does it mean the CD? For clarity, I would suggest changing the label “disk” to “drive” when referring to where the rips will end up, and “disk” to CD when you are referring to actions performed on the CD.
As I speak GB English, I would prefer to see the label “Storage” and not “Storages” on the UI.
The Daphile UI gives no obvious indication if the system is running from a USB stick or has been installed on a hard drive. The amount of “Free Storage” under “Info” is a possible guide. If someone has installed Daphile to a hard drive, but (by error?) leaves a Daphile USB stick connected they wouldn't necessary be aware of this.
Under “System Firmware” when installing to a hard drive there seems to be no check/warning that a previous hard drive installation is about to be over written.
The Daphile website says: “Since Daphile is used and configured completely via the web interface the user is not required to have any Linux skills” But the format of the network drive entries will be a mystery to some people. I am sure it would be helpful if you could find time to add some more examples/explanations to your PDF instructions or websiteabout this. It might avoid the need to respond to info request on the various forums you post on, Of course, in the long run, some kind of help facility in Daphile itself could be very useful.
Old 13th January 2014, 10:44 AM   #284
Thanks! Is it possible to turn off this scan? I mean let it scan for one time than do not scan the next time.
Old 13th January 2014, 06:03 PM   #285
From what I can tell, Daphile only scans once then updates when you add a new album. I don't have to click the Update button when I add new tracks.
Old 13th January 2014, 06:57 PM   #286
sinski is offline sinski
I have installed Daphile on internal ssd, on the first partition is Daphile, second partition was automatically mounted with a root prefix DaphileData/Music, for the second external USB HD i sad use partition, rw, share and root prefix is DaphileData/Music1, but LMS don't know nothing about it, and the page in LMS where you can set the path for the library and rescan library is not existing as in the standard LMS installation ???
added - LMS Page "basic setting" is missing.
Old 14th January 2014, 03:45 AM   #287
Absconditus is offline Absconditus  Australia
Banned
BTW, the other day a fellow diy fourmite came over to see Daphile. He brought a small USB DAC which we plugged into my old laptop running Daphile. Daphile immediately recognized his DAC. I connected this 2nd DAC to a 2nd amp and speakers. We had Daphile playing two different tracks on two different systems at the same time. (1 laptop, 2 DACs, 2 amps/speakers) I'm impressed.
I was impressed too.
The question I have relates to using Daphile for widely spaced zones, where they may be up to 15 to 20 metres from the server. What is the "best" method to get the signal that far? Is it using an USB DAC/TOSLINK and sending it via TOSLINK (or SPDIF) over that distance to a DAC that accepts that input, or using a USB DAC and converting to a balanced signal, or is it using a client and sending the signal via TCP/IP, or something else?
Any assistance here is appreciated.
Abs
Old 14th January 2014, 05:15 AM   #288
Abs
I've only been using Daphile for a month. I know nothing about Linux.
I'm only guessing but according to this guy: Archimago's Musings: MEASUREMENTS: USB Cable Extension with Ethernet Cables - does it worsen jitter?
you can extend USB by using USB ->Ethernet - Ethernet->USB adapters.
I'm sure there are other ways too.
Cheers, Mack
Old 14th January 2014, 07:26 AM   #289
Thanks. I will try to be patient and let the first scan make ready....
Old 14th January 2014, 02:38 PM   #290
ZombyWoof is offline ZombyWoof
Originally Posted by ZombyWoof View Post
I used a TP-LINK TL-WN7222N for a bit testing a smartphone as a controller, seemed to work fine.
I switched to one of those tiny usb plugs with a Ralink 5370 chip and it works fine too for remote control purposes. It has less range so there is less of a security risk to my network.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Copyright ©1999-2017 diyAudio
