PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 20th June 2018, 05:14 AM   #2881
CallMeMike is online now CallMeMike  United Kingdom
Quite a few misleading posts above regarding running DAPHILE on a Raspberry Pi... maybe it should be reiterated that DAPHILE IS NOT COMPATIBLE WITH ANY ARM DEVICE...
If in doubt check the 'Requirements' here:
https://www.daphile.com/download/Dap...stallation.pdf
Old 20th June 2018, 08:11 AM   #2882
Goto is offline Goto  United Kingdom
That's a good point. My post was made on the assumption people understood that, but maybe wasn't explicit enough.
Old 21st June 2018, 01:58 PM   #2883
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What's the hardware requirements to play DSD512 native?
Old 21st June 2018, 04:12 PM   #2884
Triplefun is offline Triplefun  New Zealand
I have an i7 7700 which up samples most formats to dsd512 with no stuttering. I do get the occassional 'blip' especially during the initial library scan. Note daphile upsampling seems to be more demanding than win10 running foobar which surprises me.
I listen, therefore I am !
Old 21st June 2018, 08:52 PM   #2885
Thank you, how many GB of RAM?
Old 21st June 2018, 09:36 PM   #2886
I have 8gb ram in a single bank but rarely exceed 2gb. Whether you need more depends if you want to make use of the play from RAM drive. I would suggest min 4GB, 8GB if you can afford it.
I run daphile from a 128gb m.2 ssd but again probably only require 32GB.
I configured the computer so I could load windows which I will probably never do.
the dsd512 cpu with the i7 load varies from 4 to 6 (peak would be 8), depending on the intensity of the music being played, orchestral being the most demanding.
Note the i7 can run 60c or higher. I tick some of the power settings (eg. wifi and video) to reduce the load (now runs 50c). I use a zalman cnps7700 which is very silent. Board is a gigabyte itx ga b250n phoenix wifi. case is an antec isk 310-150
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
