PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 19th May 2018, 04:51 PM   #2871
Meirkat is offline Meirkat
Sorry for my ignorance, but I don't understand this.
Why do I need wireless connectivity when I have a direct Ethernet connection.
Isn't wired (Ethernet) the preferred way, or am I missing something here?
Meirkat.
Old 19th May 2018, 04:56 PM   #2872
Julf is offline Julf  Europe
I guess we all took your "I would like to put my Daphile PC/Server in a separate room from my music system" as a wish to be wireless. If you can use wired, it is definitely the easiest and best way.
Old 19th May 2018, 05:06 PM   #2873
gvl is offline gvl  United States
Why one needs a Daphile machine at all if the Dac has a built-in network player?
Old 20th May 2018, 01:29 AM   #2874
roger-k is offline roger-k  Norway
Default AUDIOPHONICS DAC I-Sabre ES9038Q2M KALI EDITION Raspberry Pi
I'm considering to buying this DAC, so I wonder if there will be support for this dac?
Roger
Old 20th May 2018, 01:47 AM   #2875
rif is offline rif  United States
Neither a cowbow nor dog owner
rif's Avatar
Check out his release notes, sometimes he says which DACs he tested.
https://www.daphile.com/firmware/stable/CHANGES
Old 20th May 2018, 05:42 AM   #2876
dewy1 is offline dewy1
every dac works with Linux, but only pcm and DSD DoP mode.
for DSD native the dac id must be written in the kernel.
dewy1
Old 20th May 2018, 04:54 PM   #2877
OK, Thank you for the answers.
I'm sorry for the previous post. The background was that I thought that Audiophile was compatible with raspberry pi.
Roger
Old 18th June 2018, 10:29 AM   #2878
MSHAVS is offline MSHAVS  Netherlands
Default new beta released
New beta version(s) available:
2018-06-17 beta version 18.06-b171229 (x86_64, x86_64-rt & i486) changes:
- Local UI support added to Key Bindings
- LMS update to Jun 16th, 2018 Git version (5aee266)
- Kernel update to 4.14.50 and 4.14.50-rt30
- Bug fixes and component updates
2018-06-17 beta version 18.06-b171917 (x86_64, x86_64-rt & i486) changes:
- Quick bug fix for Settings page failure of previous beta 18.06-b171229
Old 18th June 2018, 02:04 PM   #2879
mickiboi007 is offline mickiboi007  Australia
Works with the Ultimate Preamplifer. Excellent.
Old 19th June 2018, 08:09 AM   #2880
Goto is offline Goto  United Kingdom
Roger
If you are using a R-pi, Daphile probably doesn't care what dac you have. It sends the music in packet form to the R-Pi and squeezelite (assumedly) on the Pi will render the music in I2S form for the dac. As long as your dac operates in slave mode Kali is transparent to the R-Pi or DAC.
Daphile only interacts directly with dacs or soundcards directly available on the same host hardware where you run Daphile.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
