PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 12th March 2018, 03:39 PM   #2741
alzy is offline alzy
Default Player not loading in GUI
Installed 17.09 on an older i486 pc. Seems to basicaly work except player doesn't load in Daphile gui, just says loading with the spinning wheel forever. i can go to the LMS webpage and the server is running and the players are selectable and things work but no access via the gui. Any ideas how to fix?
Thank!
Old 13th March 2018, 12:21 AM   #2742
Tromperie is offline Tromperie  Australia
Did you select the local control option when installing?
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 13th March 2018, 11:18 AM   #2743
Thanks for the reply. Don't remember if I did, but why does it just hang and forever say loading player. Seems like something is not working properly.
Old 14th March 2018, 12:35 AM   #2744
anadigi is offline anadigi  Canada
The DHCP of recent versions are not working while installation, You have to assign the static IP to finish the installation. I have sent the message to Kimmo from his web site, but haven't have any feed back yet.
Old 14th March 2018, 01:02 AM   #2745
anadigi,
This is the behavior I get with static IP assigned.
Old 14th March 2018, 06:47 PM   #2746
gvl is offline gvl  United States
Could anyone running the latest beta snap a screenshot of their audio device settings and post it here? Some time time ago I asked for a way to limit the bit-depth when resampling, and the request was tentatively okayed, curious if it has been added. I'm hesitant to upgrade my version as everything works fine.
Old 16th March 2018, 07:52 PM   #2747
Triplefun is offline Triplefun  New Zealand
The resampling bit depth has not been implemented for my sabre DACs. But everything works well. Other than a few bug fixes and DAC support upgrades the bulk of the betas are updates to the latest Linux and lms releases. It is easy to roll back if there are issues. And daphile will automatically roll back if it has trouble starting.
I listen, therefore I am !
Old 16th March 2018, 08:06 PM   #2748
Nice, this would be my first upgrade, do I just start it from the settings page?
Old 16th March 2018, 08:19 PM   #2749
Yes. See firmware update at the bottom of the settings page. Once loaded you need to save and restart for it to take effect.
Old 16th March 2018, 08:28 PM   #2750
Thanks, I'll likely give it a shot, however I'm a big fan of the "don't fix it if it ain't broken" rule
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
