PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 13th February 2018, 01:13 AM   #2701
fccn75 is offline fccn75  United States
Originally Posted by phofman View Post
fccn75: Very good, now post output of
amixer -c 1 contents
Please copy the text from terminal as code here, do not make screenshots.
Thank you for your guidance! Here is amixer contents:
Simple mixer control 'PCM' , 0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Clock Source 18 Validity' ,0
Mono: Playback [on]
Old 13th February 2018, 07:44 AM   #2702
cliver1956 is offline cliver1956
Quick question folks. I have just migrated from vortexbox to daphil and am loving it.
One thing I would like to do and I can't remember if it was possible on vortexbox or not.
Can I stop LMS from rescanning every time I move, change anything in my library?
I'm experimenting with various places to keep my library at the moment and want to get everything set up then manually initiate a rescan.
Can't see it anywhere. Is it possible?
Old 13th February 2018, 09:32 AM   #2703
phofman is offline phofman  Czech Republic
fccn75:
Thanks. I am a bit surprised the USB device defines almost no controls. On the other hand it is a very simple interface.
Now let's try playing some track directly to your soundcard.
Please post output and result of command:
Code:
aplay -v -D plughw:1 some_48k_16bit_stereo.wav
It should play the track to your SPDIF output.
Old 13th February 2018, 05:24 PM   #2704
SkipSpence is offline SkipSpence
Yes, it's possible: try Advance Media Server Settings>Advance>Performance, set Automatically Detect Changes to Disabled Manually Scan, Apply, Close. Restart Daphile.
Old 13th February 2018, 06:22 PM   #2705
fccn75:
Code:
Just to clarify, I presume that a song file has to be loaded so I placed a test file in RAM initially. hen I ssh into Daphile with "aplay -v -D plughw:1 These_Eyes.flac"
Daphile came up as "aplay: main:786: audio open error: Device or resource busy"
Next, I initiated play in audio player with the same file from RAM. GUI shows it's playing, so I set the command again, "aplay -v -D plughw:1 These_Eyes.flac"
Same result came up.
Old 13th February 2018, 06:52 PM   #2706
The aplay command is a standalone playback utility - look up man aplay on google. Other playback processes must be inactive to release the sound device. The error explains it clear - the audio device is already busy, i.e. taken by a different process.
Just type path to any wav file within the filesystem.
Plus it must be wav format, not flac. Please use google to look up details of what the commands do.
Old 14th February 2018, 08:34 AM   #2707
Brilliant, I knew it was in there somewhere. Thanks SkipSpence.
Old 14th February 2018, 10:19 AM   #2708
mickiboi007 is offline mickiboi007  Australia
I have been reading on other forums that moOde and Volumio sound better than Daphile. But I am at a loss as to why this would be so.
Anyone here agree with the above or have any reason why this would be so?
Old 14th February 2018, 11:21 AM   #2709
Why speculate about causes of a phenomenon which has not been properly confirmed to even exist? A blind listening test on one hardware (i.e. only daphile and x86 volumio, moode runs on RPi only) would be required to make such claim first. I have never heard of any.
Old 14th February 2018, 09:08 PM   #2710
Thanks, Phofman, I decided that I'm too much of an idiot to relearn command lines and just wanted to listen to music. I'm putting Daphile aside for now until more time is spent configuring and learning the CL.
On a whim, decided to try Volumio and no problems! After install to same low power atom 2800, it recognized Schiit Eitr and plays wonderfully!
So for now, Volumio for me until later on...
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
