PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 2nd February 2018, 03:44 PM   #2681
wei4135 is offline wei4135
Originally Posted by wei4135 View Post
i install Daphile the latest beta version,system restart,the screen show "grub", how can i do ?
Users have to copy the download link of
the version as text to input field besides the Install button and
press Install to process. i can't updata.
Can anyone give me some advice on it?
Thanks,
Old 4th February 2018, 11:11 AM   #2682
slmnklyc is offline slmnklyc  Turkey
Originally Posted by fccn75 View Post
Has anyone successfully used Schiit Eitr with the latest Daphile iso or for that matter any version including beta? Daphile recognizes Eitr as player though...
Tried using Modi by itself via usb, works great. Then tried usb-->Eitr-->Modi, no sound. Not sure if any relevant settings in mixer for Eitr. If anyone can shed some light on this, thanks.
I don't see any mixer settings for the Eitr
I looked at schiit eitr web site.They don't suggest untested operating systems..
Did you try different starting sequences?
Computer ON>eitr(plugged to ac) plug The usb cable..
Eitr(plugged to ac) plug usb cable to usb>>Start The computer..
Also try other eitr(unplugged to ac) configurations..
Also if you can find,check The power settings of your computer and looked at usb related ones.
Maybe these can work for you..
Old 4th February 2018, 02:11 PM   #2683
my Daphile update success by restart the route.
Old 4th February 2018, 04:38 PM   #2684
Triplefun is offline Triplefun  New Zealand
Thanks,
Have you loaded the "http://<daphile>/cgi-bin/Devel" URL to access the daphile development update page. <daphile> is the IP address or name of your daphile instance.
I listen, therefore I am !
Old 5th February 2018, 06:22 AM   #2685
MSHAVS is offline MSHAVS  Netherlands
It may be necessary to add a powered USB-hub between your PC and the Eitr. I had a similar problem with my own USB-DAC (Audio-GD). I can connect this DAC directly when I use it via a Squeezebox-Touch, but when I connect it to my PC (a NUC-like mini-PC) the DAC is not seen. As soon as I put a powered HUB in between the DAC is recognized and works perfectly. May be worth to try yourself.
Old 5th February 2018, 01:17 PM   #2686
Default my Daphile update success by restart the route.
thank you.
Old 7th February 2018, 07:06 PM   #2687
fccn75 is offline fccn75  United States
Thanks for the suggestion, I'll try different combination of startup and see what happens. The strange this is that it does recognize the device and even list name of Eitr.
Old 7th February 2018, 07:12 PM   #2688
Hmm...that's interesting, thanks, will try adding a powered usb hub and try again along with startup sequence.
I recall reading on page 160'something where a similar usb to spdif transport was successfully used. So that's why I wanted to try the Eitr.
In each case, Daphile recognizes the device with music actually playing as shown on gui, but no sound. Or rather, signal is not coming out of Eitr's spdif port into my other Schiit dac.
Old 9th February 2018, 06:30 PM   #2689
cliver1956 is offline cliver1956
Thumbs up Successful Install on ex thin client. Add USB CD?
I have just discovered this great project while looking to upgrade my old 32 bit vortexbox.
Installed without problem on an ex thin client as follows:
HP Mini Silent PC
AMD Dual Core 1.2GHz GX-212JC; with AMD Radeon Graphics
4GB DDR3 RAM
16GB SSD
2 x USB3
4 x USB2
2 x Displayport (comes with 1 x HDMI adapter)
1 x VGA
1 x Ethernet
My music library is on a synology NAS and all seems to be working fine .
The only thing missing is a CD ROM to rip my music from. No deal breaker because I can rip on my other machines.
I'd kind of like to try it though. So, can I use a USB CD/DVD drive? Will any drive work?
Thanks again for a brilliant project.
Old 10th February 2018, 06:10 AM   #2690
Tried with powered usb hub, still no go - just not outputting via spdif from Eitr. Strange, as if driver related problem. Same as before, pc sees Eitr and plays as if normal state with other dacs. Too much time spent instead of listening to music
Daphile - Audiophile Music Server &amp; Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
