RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player - Page 29 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 26th March 2014, 03:42 PM   #281
pinnocchio's Avatar
Originally Posted by mikelangeloz View Post
Back! Yeah I agree to change the title to Volumio... Maybe the mods can help on that.
And, regarding Volumio for UDOO. Don't worry, the update is coming. I am just active on lot of fields right now... So, please be patient.
I have the 1.3 UDOO version ready, I'm just testing it prior to release. Pinocchio, you won't regret to have choosen it...
I was also asked for i2s output for UDOO. Unfortunately there is no i2s driver yet, hope that someone would hop on that and help...
Thanks, that is really appreciated!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 26th March 2014, 06:02 PM   #282
JLOP is offline JLOP  France
Hi Michelangeloz
Is Cubieboard3 / Cubietruck implementation within Volumio planned ? There is I2S capability, I do not know if useable. It is priced 96,5 € in France which seems competitive.
Anybody has an experience with this board ?
BR
Jean-Louis
Hardware Specs
  1. AllWinnerTech SOC A20 ARM® Cortex™-A7 Dual-Core ARM® Mali400 MP2 Complies with OpenGL ES 2.0/1.1
  2. 1GB/2GB DDR3@480MHz
  3. HDMI&VGA 1080P display output on-board
  4. 10M/100M/1G Ethernet
  5. Wifi+BT wireless connection with antenna on-board
  6. SATA 2.0 interface support 2.5’ HDD (for 3.5’ HDD, only need another 12V power input)
  7. Storage solution NAND+MicroSD or TSD+ MicroSD or 2*MicroSD
  8. 2 x USB HOST 1 x OTG 1 x SPDIF 1 x IR 4 x LEDs 1 Headphone 3 x Keys
  9. Power DC5V @ 2.5A with HDD support Li-battery & RTC
  10. 54 extended pins including I2S, I2C, SPI, CVBS, LRADC x2,UART, PS2, PWMx2, TS/CSI, IRDA, LINEIN&FMIN&MICIN, TVINx4 with 2.0 pitch connectors
  11. PCB size 11cm *8cm*1.4mm very suitable for installing a 2.5’ HDD
Old 3rd April 2014, 04:39 PM   #283
Originally Posted by JLOP View Post
Hi Michelangeloz
BR
Jean-Louis
Hardware Specs
Hi all
no user for the Cubietruck ?
Old 3rd April 2014, 11:18 PM   #284
keres is offline keres  Italy
For udoo user I suggest to use the hidden usb port with your dac.
The connector is in the udoo starter kit but I thing it is avalaible also in udoo shop as single cable.
Pheraps it is only in my imaginary :-) but I thing this is the more musically usb port in udoo.
Inviato dal mio SM-N9005 utilizzando Tapatalk
Old 4th April 2014, 02:08 AM   #285
tjaekel is offline tjaekel  United States
I have a CuboxPro and Cubox-i4.
I am not aware of an I2S output, maybe internally (if you open and break it out).
For sure, there is a TOSLINK (optical S/PDIF) output.
I have tried:
- works but "strange":
- my TOSLINK receiver tells me: "signal with Emphasis" and
- I have to lower the volume drastically (SW Loudness), otherwise just distortions,
audio is not very loud then
BTW:
My Cubox-i4 comes with Android. I do not have found a way to configure TOSLINK audio out. I have installed XBMC for it, works, and I was able to configure once the audio to have TOSLINK working).
To try Volumio on Cubie would be nice.
Best regards
Torsten
Hi all
Old 13th April 2014, 01:40 AM   #286
pinnocchio's Avatar
Any good news for volumio 1.3 for Udoo?
Do
Old 13th April 2014, 09:23 AM   #287
The release for Udoo was ready, then I discovered a bug which required mpd to be recompiled (and for some reasons, it didn't recompile on my dev environment) so it is a little delayed.
After that I'm making the cubietruck porting, which is complete, exept for the kernel which I have to recompile, and throws errors which I have to further investigate...
So sorry pinocchio if I'm making you wait so long... But sure it will be worth it...
Old 13th April 2014, 09:25 AM   #288
Yes, I can confirm this. Also, for a really strange reason, it is the USB port which can be handled by jack audio server in pre-emptive mode...
Maybe if we look at the schematics we can understand why...
Old 13th April 2014, 07:16 PM   #289
clsidxxl's Avatar
Hi mikelangeloz,is that the version for cubietruck will be compatible with Ibox (Allwinner Technology A20 Dual Core) https://www.indiegogo.com/projects/i...board-computer
Thank.
Old 14th April 2014, 03:30 AM   #290
pinnocchio's Avatar
Thanks!
Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo Quad tuxx PC Based 96 8th June 2017 07:05 AM
Volumio (ex RaspyFi) Audiophile Music Player for embedded systems mikelangeloz PC Based 115 8th March 2017 10:58 AM
Volumio, Raspberry-pi and hardware volume control hugobors PC Based 4 2nd March 2015 12:34 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Raspyfi (raspberry pi) regulators kentxon Digital Source 0 18th November 2013 07:59 AM
Copyright ©1999-2017 diyAudio
