Tweaking a cheap Tenor TE7022 USB converter board - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 1st May 2013, 10:22 PM   #21
Because the clock is now on a different board, I don't think I need 5V on this board at all. Can someone recommend a low noise 3.3V surface mount regulator to replace the one that is already on there?
Old 2nd May 2013, 07:24 AM   #22
marce is offline marce  United Kingdom
Heretic
Firstly what regulator is on the board. It may also be adequate for the job.
Old 10th May 2013, 02:29 AM   #23
Printed on top of the 3.3V regulator is "112ZE 17-33".
Old 10th May 2013, 07:32 AM   #24
Heretic
Initial search drew a blank!
Old 10th May 2013, 05:01 PM   #25
It was the same when I looked too. My guess is that it is pretty low quality.
Old 10th May 2013, 06:17 PM   #26
phofman is offline phofman  Czech Republic
My 2 cents - a clone of http://www.datasheetcatalog.org/data...1/216987_1.pdf - page 6 upper right corner?
Old 14th May 2013, 09:03 PM   #27
Good find, but I think it looks more like the first chip on that page: SOT223-3L. The markings would fit with the description. Output Type: 3.3V, Year: 2001, Month: 12, ID Code: ZE (whatever that refers to)
I didn't mention that there is a backwards "C" before the "112ZE". Maybe the backwards "C" is the logo of the manufacturer?
Old 9th June 2013, 06:37 PM   #28
So does anyone think it's worth replacing the 3.3V regulator?
Old 11th June 2013, 04:48 AM   #29
McLanz had the advice of using a battery for power. Could a simple 9V alkaline or Ni-MH battery be used instead of the bigger and more expensive lead acid battery?
FS:Finished USB DAC - WM8741 & Tenor TE7022 diyhifishop Vendor's Bazaar 19 8th August 2016 09:24 AM
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 02:46 AM
WEILIANG DAC5 - WM8741 & Tenor TE7022 dhalbakken Digital Source 396 10th August 2015 10:10 AM
Cleaning continues - FS: Amanero USB to I2S 384kHz DSD converter board ultrafi Swap Meet 4 23rd February 2013 12:39 AM
FS: Amanero USB to I2S 384kHz DSD converter board ultrafi Swap Meet 4 20th February 2013 11:36 PM
Copyright 1999-2017 diyAudio
