| PC Based Computer music servers, crossovers, and equalization |
#21 |
Thanks Hengy. I have tried once or twice, hooking the headphone out from a netbook to an audio system. Too much noise (hiss -- probably RFI). Funny, it works fine with headphones. I soon bought a cheap USB audio DAC which sounded much better. Currently I have a USB->SPDIF (Toslink or Coax) so I can feed my DAC(s). I probably will remain with the Windows platform, mainly because I like the option of staying with my current softwares, and including the ability to stream music via a web app.
#22 | |
Probably USB out with USB isolator using external supply is the best solution there (A&B Systems). Or USB to optical SPDIF for complete galvanic isolation. I really only use it to explore artist back catalogs on free version of Spotify, not serious listening. |
#23 | |
#24 |
I just did a quick look at Squeezebox on EBay. Still have new/used. I know little about these products, but from the prices I can do the same or better with a cheap netbook or similar (I already have my choice of external USB, TOSLINK and three DACs possible.) I am quite sure I want to remain with the WIN platform (even XP is fine) -- because I'm used to the music players (I use Winamp, Foobar and Itunes all for slightly different reasons). I am interested in those Linux based boxes -- can I slap XP or later Win on them? If the fan whirreth not, speak!
#25 |
I've done some more Ebaying. I saw a Viewsonic VT-something. Price marginal (Win XP). Prices are not competitive with low-end netbooks/notebooks. I am starting to get disheartened! Looks like I will be resurrecting the old Frankenputer (Originally a Micro Center Powerspec ...something) with my $12 "soldermized" PSU (remove fans, and it will work ... for six months anyway). No covers, no fans (except the tiny CPU fan) and ... full PC power. Or maybe try the quieter spare laptop ... for just a music PC....
Where is the $50 all-in-one metal brick, no fan, ten USB 3.0 Ports, runs on 12V (external), 8 GB RAM, huge SSD internal ... add your own OS ... ok I am tripping! ![]() Aw heck, why not go back to childhood when things were simpler. How about a ... http://www.ebay.com/itm/Kenners-Clos...item1c307b3eda Last edited by Soldermizer; 26th February 2013 at 12:23 AM. Reason: double posted, so created a whole new message! |
#26 |
I am building a silent media PC myself. The small netop computers like Intel NUC, AMD E-450 or Atom D based all look tempting in the $200-300 price range. Some of them have fans but I imagine you could gut them out and install a passive heatsink.
Intel BOXDC3217IYE Intel QS77 2 x 204Pin Intel HD Graphics 4000 Integrated by CPU Chassis: Aluminum and Plastic Black Next Unit of Computing Kit - Newegg.com Zotac ZBOX ZBOXNANO-AD12-U Mini / Booksize Barebone System - Newegg.com I ended up with an overkill system mainly because of reports that AMD APUs and Atom CPUs can't stream Netflux. 3 years a go I built an i3 Core system on an ITX board with a picoPSU silent power supply and a giant passive cooling heatsink. It has worked so well that now I find myself building again an i3 system just a later generation. Cost-wise my system will be at least double that of those small computers I linked above but I have some of the parts already. It's a crappy time to be on the market for a small fanless computer. They will get much better in a year or two. Interestingly though, I thought the same thing 3years a go and although AMD's APUs and Intel's Atom line have improved significantly they are still have some way to go. I took a risk with a costly i3 system but if it remains current for another 3 years I will consider it a success. |
| Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? | edbk | PC Based | 0 | 1st May 2012 02:40 PM |
| The "Freebird" ultra clean ultra simple preamp design | Russ White | Chip Amps | 87 | 11th August 2008 09:28 AM |
| "Voronoi Visolate"-ing PCBs? | DJ Exprice | Parts | 2 | 30th October 2006 01:47 AM |
