PC Based Computer music servers, crossovers, and equalization
USB cable quality
USB cable quality
Old 22nd January 2013, 07:25 PM   #31
marce is offline marce  United Kingdom
USB cable quality
one of; if not my ultimate favorite comedy sketch! still love the manic comedy of Mr Hicks and Mr Leary etc, a lot of comedys so tame these days.
Yes form what I've seen of your posts so far I would say we agree, I just word it different, I would say I use quiet frustration in my replies.
a bit of boring SI (Signal Integrity) since we are on about digital. Most non monotonic signals I see using SI are on multi source parallel recievers with a single driver (some clocks). This is solved by some quite often complex termination schemes often involving a series termination resistor to slow the initial wave into the single trace from the driver pin, with AC parallel termination at each receiver to match the lines, and the overall impedance seen by the driver chip. Also generaly the driver is a bespoke driver chip, and these do seem to have a agressive current drive, to drive the multi sources, think JTL05 (JTAG idriver) and such like.
Regarding signal transmision and cables, I have to admit they DO make a difference, we once had to create a digital interface that would operate a relay box, up to a kilometre away! normal bell wire would work up to 200m, beldon twisted pair shielded cable (5000+ for a km) worked to 1km, 40X the cost of the relay box. So personaly I wouln't worry to much about a metre or so of USB.
And remember its just a ride
Marc
Old 23rd January 2013, 12:36 AM   #32
lowtherdream is offline lowtherdream  Canada
lowtherdream's Avatar
Originally Posted by analog_sa View Post
Looks like this is the thread for USB audio virgins
Come on guys, do just a bit of research on async transfers as pioneered by Gordon Rankin and pretty much the standard today and the amazing thread about Ian's FIFO.
I admit, I'm a USB virgin... and I plan to stay away from Goatboy .
Time to read some more ....
surfing the 2nd harmonic ... @@@@
Old 25th March 2013, 12:35 PM   #33
xcomrider is offline xcomrider  Indonesia
i find some usb cable with noise isolation ...
feel more comfortable...
and i mod it like this :
Old 25th March 2013, 01:04 PM   #34
johnm is offline johnm  United Kingdom
johnm's Avatar
This is a side of being an 'audiophile' that I absolutely detest these days. A bog standard usb cable was/is perfectly fine, and capable of allowing any number of documents to be printed without a single letter out of place. Or transmitting high definition video without any glitches. Or incredibly detailed photos, again without any visible glitches. However as soon as its audio related, NO it suddenly cannot be good enough unless it has been branded by one of the greedy audio manufacturers like Kimber or Audioquest! It's ridiculous - it's almost as if audio has the magical ability to suddenly ignore the laws of physics!!! No matter what accessory it is, it automatically cannot be good for audio use (despite being fine anywhere else) unless some audio company has their branding upon it! I get the impression many seriously believe this too, and thus a whole sub-culture of snake-oil accessories has sprung into being over the past couple decades. No you can't measure it folks, but if you have good hearing & your system is good enough you can Therein lies the root of the problem - advertisers were cleverly able to exploit this 'audio snob paranoia' and when you dish out the same BS year after year after year and the magazine writers concur it eventually gets accepted as truth without being questioned by the mainstream.
Perhaps people need to wake up to the fact that proper designers who KNOW their field have already done the design work/worrying for us! Belkin for example. A Belkin USB cable will be as good as anything out there. Why? It's been designed by people who know their jobs. Stop worrying about it - move on! Not some audio company who rely on tooting cryo freezing, thick impressive looking connectors and fancy jackets instead...
I'd love for some audio magazine to grow a set of balls and denounce all this rubbish, but they won't as they have to rely on advertising of course and live in the pockets of sponsors and manufacturers. I'm embarrassed to say I believed it too for a few years, before I got into DIY and could actually see & hear the results by building my own equipment.
Always find it somewhat amusing that many 'audiophile' favourite albums (i.e. Mercury Living Presence, RCA, Blue Note etc) would have been recorded without ANY wanky cables at all, but bog standard tin-plated copper - The Horror!
John
Old 25th March 2013, 01:04 PM   #35
phofman is offline phofman  Czech Republic
IMO most noise into USB comes from the 5V PC supply and the noise on the data pins originating again in the PC. USB is twisted pair + differential mode, just like ethernet (without galvanic isolation).
Old 25th March 2013, 02:13 PM   #36
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
And [phofman], absolutely none of that "noise" matters one iota. Not one scintilla. Not one sesame seed in a bucket of hummus. Why?
Because its digital... is why! Digital was designed to have TWO states, which we say "1" and "0", or true/false. As was so eloquently said by [johnm] above, millions of images, having millions of bytes (i.e. terabytes) of information can, and is transmitted over a bog-standard USB cable, flawlessly ... over the years of its service. Heck... in our rack of ultra-high-end database processing servers, ALL the disks are external, and all are hooked in via bog-standard USB cables. These transmit and receive terabytes per cable per day ... and MUST do so flawlessly. If they don't, if even on bit is flawed ... the error is detected, corrected in microseconds, and it gets logged in the server data-exception logger. I've checked that logger, like religion once a week or so, for 4 years. Not one unintentional data bit lost.
To jigger the system, I actually took an old USB cable and pounded on it on an anvil with a hammer - enough to expose the wires, and be "horrible". Then I dipped it in salt water, just to add more degradation to things. Had it in a little bucket of salt-water. After trimming away the bits of wire that were shorting it out, I hooked it up to see if the logger would log anything. [I mean, if it reports nothing and always has, then it could be deaf to the problem!] Sure enough, the logger immediately started to complain about lost bits and retransmitted packets. Yet, 99% of the packets magically got through. And, at the other end (the disk), when we finally disconnected it a few days later, hooked up a proper cable, and then READ BACK all the data that had been recorded... guess what. ZERO data errors. None. That absolutely shitty cable and its data atrocities ... didn't affect what had been recorded at the other end at all.
So... let's just go back to basics on the USB cable front. Buy decent quality, not bargain basement, and especially not "audiophile grade" cables. Belden makes great wire, if you're building your own, and Belkin makes great cables.
GoatGuy
Old 25th March 2013, 02:32 PM   #37
GoatGuy
Did you notice I did not talk about noise induced into the cable, but about noise originating in the PC itself? That kind of means I was giving reasons why the cable itself is not that important
Those who know me from this and other forums can confirm I am very oriented on technical and hard science facts. If someone claims to hear something, I challenge him to confirm his assumption with a blind test (almost always with very negative response, to tell the truth ).
Yet I would not say USB audio is about zeros and ones. The noise coming over from the PC (even if the DAC has its independent power supply) simply affects the analog circuits, there is no way it would not. Unless great care is taken by the manufacturer. Is it audible? It certainly depends, a blind test would reveal the truth. It is perfectly possible many people can hear the difference as there are sound technical reasons behind it. Will they take the test? Well, ...
But again, the above is not about cables
Old 25th March 2013, 05:43 PM   #38
GoatGuy's Avatar
IMO most noise into USB comes from...
Dunno. I interpret those words as you saying "most noise into USB comes from...". You din't say "into the sound card", or "into the output jack" or "into the USB DAC on the preamp/amplifier chain"... how was I supposed to know that you were referring to the more abstract "noise in the audio system(s) inside a PC?" And you know, I would say that "into USB" very particularly means "into the USB port, into the USB jack, into the USB cable" in combination.
But in any case, thank you for clarifying your position.
I appreciate (deeply) that you're the kind of bloke that insists not just on A/B tests, but "blind" A/B tests.
I hooked up a cool circuit a few years ago that made it utterly random... using two boxes. One was the supposed "a/b/c" switch, which would assign to the three positions one of the combinations at random: ABB BAB BBA AAB ABA BAA ... and would keep that random setting until the RESET button was pressed (3 times, to protect the results!). There were also 3 buttons to record "same", "worse than previous" and "better then previous".
A nice voting system, really.
You would choose the A, B or C hookup (not knowing whether any of them were really A or B), in any order, over and over, voting each time. (Required vote!) A little ARDUINO circuit kept tally of channel selects, votes, switch settings, lit up LEDs and so on. At the end, the "result" button would show the sum of "is better" minus "is worse" for the A and B test signals.
At the remote end, a small project box had a set of jacks allowing for the A/B selection and pass-through. Used reed relays to engage things. It also allowed "10 things to be switched" (since many A/B tests require changing more than just between two signal paths.). 2 of the inputs also had high quality attenuators on them, to allow for setting normalized signal levels.
What we found: when there was a big difference, within about 10 votes or so, the trend was clear. When the difference was small, it would take about 35 votes to get a clear trend in preference. When the difference was really, really subtle ... over 100 votes. And when there was intentionally no difference at all (if AAA or BBB was allowed!) then the DIFFERENCE between preferred channels was so small at 100, that it suggested "a push" (in other words, the system worked as intended)
By design, the box would never display WHICH of the buttons (A, B, C) was assigned to which channel setting (A, B). Therefore, there was no way to "cheat" - even for me, the inventor. No telltales, no tiny light glitches to use to cheat.
And you're right - its not about cables.
GoatGuy
Old 25th March 2013, 05:49 PM   #39
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
A nice test setup, GoatGuy!
Does it still exist? And what about making it accessible to forum users for A/B blind testing?
Rundmaus
Old 25th March 2013, 06:02 PM   #40
GoatGuy's Avatar
To be frank, I've moved a couple times since I built it, and I've seemed to have misplaced it. Can't find it for my life. I mean, I know I have it... but so far, its in a mystery box. Sigh... the perils of moving.
GoatGuy
USB cable qualityHide this!Advertise here!
How to isolate USB instrument from interference conducted by the USB cable sunkai Parts 3 25th April 2014 02:19 PM
USB Cable sergedc Digital Source 3 23rd April 2012 11:44 AM
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 08:47 PM
USB DAC (in the cable!?) rjm Digital Source 5 13th May 2004 08:19 AM
