Hi and thanks for reading this post.
I just purchased a hrt music streamer pro usb dac to connect my pc to my amp.
The hrt has output via 3pin xlr and my quad 405-3 amp has input via phono so i used a mini xlr to phono adaptor..
Immediatly upon plugging in the hrt i heard a loud buzzing sound which fades after the first 10 seconds, this has never happened before but it now happens every time even when the amp is totally disconnected and i am trying to find out why it keeps doing this.
I contacted David from net audio who makes the 405-3's who said it sounds like the bridge rectifier is damaged and it is charging the power supply smoothing capacitors at different rates.
I don't know as the capacitors and bridge rectifier are brand new and i choose really high quality vishay units so find it hard to believe they have failed so early.
The mini xlr phono adaptor connects pin 1 and 3 of the xlr to the outer screened cable to the phono and pin 2 is hot.
Do you think it is okay to use these adaptors or are there any compatibility issues as some people do not connect the drain wire.
Many thanks in advance. John.
