PC Based Computer music servers, crossovers, and equalization
EASY FIR crossover PC based+DRC
Old 22nd May 2013, 05:06 PM   #51
pos is offline pos  Europe
pos's Avatar
Hi soundcheck,
I answered to your point 1 in the rePhase thread :
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 22nd June 2014, 09:46 PM   #52
ra7 is offline ra7  United States
Hi Thierry,
Just wanted to say thanks for this thread. Lots of helpful tips and tricks. I put together a system with the miniDSP USBStreamer that has 8 channels on I2S output together with 4 Curryman DACs. Using JRivers internal convolution engine. For measurement, I use the ASIO loopback that works without stutters. More details here:
http://www.diyaudio.com/forums/pc-ba...ml#post3968871
Old 4th October 2015, 05:31 PM   #53
TJF is offline TJF  Germany
after a first look: very impressive! But one question: How (or where) can a time delay be set? I mean time-alignment-difference between LP and HP (position of speakers on x-axis) in example?
Thomas
Old 4th October 2015, 09:47 PM   #54
thierry38 is offline thierry38  France
Default Hello,
In the convolver file (.txt)
each delay for each channel can be set manually
see the convolver site.
Config file
and some examples
Config examples
in the 2nd and third line,delay is setting in ms for input channel,
and for output channel in the third line.
44100 2 2 0
0 0 (=no delay in ms for the two input)
0 0 (=no delay in ms for the two output)
C:\Impulses\LeftIR.wav
0
0.0
0.0
C:\Impulses\RightIR.wav
0
1.0
1.0
44.1khz, stereo in and out, no speaker mapping
No delay on any input channel (feature introduced in version 3.1)
No delay on any output channel (feature introduced in version 3.0)
Take the first (and in this case only) channel from Left.wav
Apply Left.wav to the first input channel
... and output the result to first output channel
Old 5th October 2015, 04:09 PM   #55
Thank you very much!
Is there a description about the measurement-import format from any hardware-measurement-equipment? Would it be possible to upload such a demo-file (for coding an interface)?
Is there any basic-experience how to avoid audible preringing (i.e. no sharper filters than ...)? Over-all (room-) corrections only with minimum-phase-filters?
Old 20th January 2016, 05:16 PM   #56
critofur is offline critofur  United States
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Hello, the images seem to be missing now - could you upload them to DIYAUDIO.com as attachments since 3rd party image hosting sites always seem to stop working before long?
Old 25th January 2016, 07:02 PM   #57
"Houston,we have a problem...";
Because images have not been saved,on any hard disk.
so it's lost forever.
You can find information on rePhase topic,maybe Jriver forum.
And convolver site too.
EASY FIR crossover PC based+DRCHide this!Advertise here!
iDFT-based XOs (FIR) steph_tsf Digital Line Level 15 5th November 2013 10:59 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Is there any PC based software to crossover the L & R channels to the sub? spot PC Based 11 29th November 2011 11:46 AM
Looking for a New PC based Loudspeaker Crossover - What is available? mikaljones21 PC Based 9 28th June 2010 02:53 PM
Linux XO/DRC Fanless PC w. Lynxtwo jon_denmark Digital Source 6 20th July 2007 06:54 AM
