Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 15th November 2012, 08:51 PM   #41
nigelwright7557's Avatar
Originally Posted by marce View Post
A few notes on spread spectrum SMPS's,.
I use spread spectrum pulses on a flyback SMPS and the transformer plays some great tunes on power down.
It uses 4 different pulse widths depending power demand.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 16th November 2012, 08:45 AM   #42
marce is offline marce  United Kingdom
Yes they can sing.
One advantage of multiphase is you can use cheeper and smaller magnetics, often off the shelf Wurth parts or similar.
Here is a link to another thread that has some relevant info in the links regarding keeping the noise down, filtering etc:
Switcher EMC design
Old 5th December 2012, 09:43 AM   #43
Other SoTM products that supposedly filter & solve/reduce a PC noise problem is the SoTM USB PCI/PCI-E cards.
SOtM - Ultimate High Performance Audio
These things are more than twice the price of a decent sound card in the UK and for all I know are just more audiophile bs.
Is there any merit in these products? I'd particularly like to hear marce's and phofman's view.
Old 26th December 2012, 02:40 PM   #44
What do you think about this product?:
APEXI Power Filter Card for Computer Audio Enhancement for PCI and PCI E Slots | eBay
Old 27th December 2012, 08:49 AM   #45
Not a lot. Filtering has to be done in the right place, or the noise is out there. And whilst SMPS docontribute some noise to a digital system, but the system switching also conributes a lot on noise. Also the supplies on PCI will more than likely be routed down to a voltage plane, so sittibng the filter in the middle of a plane wont do an awful lot.
The Sota cards, again may have some effect, but again I think they are taking advantage of the fear of noise, and as there marketing says...I have highlighted the relevant word, could.
For this purpose, tX-USBexp has noise filter circuit which could reduce the noises inside of PC affect to USB audio devices, and also use Ultralow noise voltage circuits and ultra-low-jitter oscillator circuit to reduce the noises causing the product itself.
Basicly if the noise reduction isn't built in to a digital design through proper design strategies then these are only like putting a sticking plaster on a gaping wound (IMO)
Old 27th December 2012, 11:33 AM   #46
JLOP is offline JLOP  France
Hi Marce
You are of course right, better design is superior to remedies. But how to select properly designed components for Pc based music centers ? No or few data is available on that issue on datasheet ? How to manage it practically ?
BR
Jean-Louis
Old 28th December 2012, 01:58 PM   #47
A thread here is discussing motherboards:
Best Motherboard for Audio
I use logitech squeezboxes over wireless so have full galvonic isolation. PC components generaly will not publish noise figures, not a good marketing move, and also somewhat dependent on other parts of the system.
Old 14th April 2013, 11:58 AM   #48
Smile A great PCI HiFi
I found a great pci power noise filter "AXF-104 Pro"
Old 14th April 2013, 02:07 PM   #49
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
whats great about it? what exactly will a bunch of normal quality polymer electrolytic caps do about smoothing a HF signal? it will at the same time depending on what its connected to, reduce the effectiveness of the regulation, so may actually make noise worse
Old 14th April 2013, 03:00 PM   #50
Regarding spread spectrum SMPS for audio:
First does spread spectrum include phase modulation (as opposed to frequency)?
It would appear to me that given a fair comparison (same number of converters near their sweet spot etc) the total radiated energy is the same, thus its just it's characteristic that can be changed from narrow peak to modulated multiple peaks.
Although possibly measuring better wouldn't any kind of frequency modulation potentially introduce components moving throughout the audio range?
Wouldn't it be better to synchronize switching frequencies with the sampling systems, such as the DAC's ? At least then aliasing shows up at dc and one can even adjust phase to minimize this dc effect?
-Antonio
DIY power filters? ak_47_boy Everything Else 2 18th November 2006 11:33 PM
FS: Capacitors/ Opamps/ Power Transistors/Noise Filters & Other Interesting Stuff dtm1962 Swap Meet 1 8th February 2006 04:21 PM
PC Power supply noise problem with sound cards - need help halcyon Digital Source 20 22nd June 2005 06:38 AM
Copyright ©1999-2013 diyAudio
