Any Diy PC Power Noise filters ? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 14th November 2012, 08:15 PM   #21
qusp is offline qusp  Australia
qusp's Avatar
ok, lets leave the clerics marce, perhaps they have discovered the 'dark bit' ? one that makes it through an EAC ripping undiscovered and the sneaky little blighters then make it through several buffers and reclocking stages to ruin the audio by removing actual music bits, but only the audio, doesnt seem to ruin other data, must hate music? only seems to have an effect if you believe though...
just like you can have caps that are 'too good' for the opamps, because the 'analogue current' (not to be mistaken for digital current) sounds better through the higher impedance decoupling cap, which must have leads (actually this is where they switch to technical language and call it linearity)
Old 14th November 2012, 08:28 PM   #22
sandyK is offline sandyK  Australia
but getting data from a to b has been worked on for decades now,
Just don't expect a .wav file sent sent to the other side side of the world via a Server such as Filemail to sound quite as clean as the original, with low level ambience unaffected.
Sending a .wav file as an UNCOMPRESSED Zip as Cookie Marenco does, helps to prevent low level degradation due to servers and numerous optical repeaters.The .flac container also appears to offer protection.
There has been extensive testing done in this regard with numerous recipients worldwide, including John Kenny and the designers of the well respected Windows software player "jPlay"
O.K. I am no longer a participant in this thread.
Alex
Old 14th November 2012, 08:43 PM   #23
qusp's Avatar
yeah sure you are...
Old 15th November 2012, 06:16 AM   #24
marce is offline marce  United Kingdom
Please explain or point to further information, SandyK.
Old 15th November 2012, 09:11 AM   #25
phofman is offline phofman  Czech Republic
Don't ask for things you are never going to get
Please let's return to the useful and contributive focus of the original thread, I found it very interesting.
Old 15th November 2012, 11:32 AM   #26
YesI should have learned by now...
Old 15th November 2012, 11:46 AM   #27
qusp's Avatar
its only useul to a point, marce is right, the only and best way to deal with the PC noise problem is to disconnect it, add isolation and forget about tweaking it because you will never solve all the problems, we all know the wav will survive intact, just isolate then reclock locally at the dac.
so while its an interesting enough intellectual exercise, IMO its a waste of breath/resources
Old 15th November 2012, 11:49 AM   #28
Originally Posted by qusp View Post
its only useul to a point, marce is right ....
Marce's post is part of the useful original thread
Old 15th November 2012, 11:51 AM   #29
qusp's Avatar
I see what you did there
Old 15th November 2012, 12:02 PM   #30
Face is offline Face  United States
Face's Avatar
Originally Posted by JLOP View Post
Of course they wont filter aerial noise, and they are pretty expensive at 300$ and big inside a PC. https://coreaudiotechnology.com/prod...atx24s1-detail
Do they work ?
Has someone tried a DIY on that, I guess the filtering techniques must be quite easy ?
BR
FYI, the item on that page is now $450.
These appear interesting though: https://coreaudiotechnology.com/prod...ies/dc-filters
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
PC Power supply noise problem with sound cards - need help halcyon Digital Source 21 17th February 2017 01:45 AM
DIY power filters? ak_47_boy Everything Else 2 18th November 2006 11:33 PM
FS: Capacitors/ Opamps/ Power Transistors/Noise Filters & Other Interesting Stuff dtm1962 Swap Meet 1 8th February 2006 04:21 PM
Copyright 1999-2017 diyAudio
