Best Motherboard for Audio - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 27th December 2012, 08:34 AM   #41
skibum is offline skibum  France
Originally Posted by geraldfryjr View Post
The board is advertised at -108db for noise or at least THX compaiable.
Clearly by this shot the inputs are better than that and there are a few pulses of noise but they never go above -108db.
jer
Looks like a very good setup! Can you look at the noise levels at higher Frequencies? USB2.0 runs at 250MHz and up so the noise levels at these high frequencies are what I am most interested in.
Thanks!
Old 27th December 2012, 09:38 AM   #42
These noise levels are the input noise levels as stock and open and unterminated using the onboard 24 bit A/D's.
I don't have any other means of checking at higher frequency's other that my 60Mhz Hitachi analog scope.
The scope is getting old but I did used to be able to detect signal up into the 100Mhz range with it.
I will try to get some screen shots using it when I do some more testing.
Right now I am basically in the overclocking testing mode at this time and making sure that all of my versions of OS's work on the system.
I just loaded Win7 and Linux Mint 14 KDE works good off of the CD.
But, I am having a bit of difficulty getting Linux Mint 14 to boot from off of the hard drive.
I will have to try Mint 13 as I never had an issue with that version.
This board has an IDE interface and I am using a IDE DVD drive and the hard drive is SATA.
I did read of an issue about an IDE controller conflict and there maybe a fix although I don't think that is what is wrong.
It is also a UEFI bios and there may be some kind of issue about that and the Linux Boot loader installer or so I have read.
Nevertheless I will figure it out later.
I have the same issue with the UD3 board and Linux Mint 14 as well as my Friend has the same issue with his UD5 board.
But I will try hooking the inputs of my Trusty Gina24 and/or my X-FI card up directly to the outputs and try to get a noise reading from the outputs of the onboard sound system using them as well as the scope.
The last onboard sound system that I heard was an X-FI engine from an ASUS Crosshair 4 AMD setup and I think that it uses the same Realtek chip for the A/D's and D/A's.
I will have to look that up again to verify it.
Otherwise I heard no issues with that system and was very amazed on how well it sounded.
I was listening through some good wireless headphones (Creative's I think) and our ole' KRK 6000 nearfield monitors on a Alesis RA 100 amp through a Beringer mini Mackie look a like mixer.
I was Quite Impressed I should say!!
jer
Old 15th January 2013, 01:09 PM   #43
Originally Posted by awpagan View Post
Hello
IMHO
It all depends on whether you're looking at analogue out or spdif out, of the pc.
Analogue out of pc motherboard is ... well... hmmm... not really high end.
spdif can be better but pc motherboards don't usually isolate the digital output (as in (transformer)
I'm latching on to this conversation. I'm not looking for USB audio, but for ANY motherboard with a transformer isolated digital spdif output (not toslink). Does it exist? Has there ever been one?
If not, any kits or diy layouts for said solution that could be installed to the spdif header?
Old 16th January 2013, 02:40 AM   #44
Default Music format?
Originally Posted by skibum View Post
I am building up a "high end" computer to be used for audio use only
What format of audio files are you playing? PCM? WAV? FLAC? MP3?
MLStrand56
Old 16th January 2013, 05:12 AM   #45
My Asrock motherboard has both coaxial and optical SPDIF outputs.
I am sure that you can easily make a transformer isolation adapter very easily,
Jeff Rowland :: BNC S/PDIF and Transformer Coupling
using this part,
https://www.google.com/search?q=PE65...hrome&ie=UTF-8
http://datasheet.octopart.com/PE-658...et-8399145.pdf
PE-65812NL - Pulse - PE65812NL - datasheet
skibum, I haven't been able to find any significant RF noise energies coming out of the system using my scope even with the sensitivity up as far as it would go at 5mv per div.
Even with the scope connect to the case my ambient noise is much greater than any thing coming from the computer.
I did make some pictures of the scope but there really wasn't any thing to show except the noise getting picked up from my CRT monitors being on.
Here are a few more screen shots of some loopback tests through my mixer.
The second picture is of one of the inputs with a 1KHZ signal from the computer, and, the other input is shorted at the computer without the mixer.
Two other test show a 1Khz and 20Khz 5mv Triangle wave that is created from TONE signal generator program the waveform may have been in a 16bit output mode in this test by the looks of the 20KHZ signal.
But the sampling was done in 24bit.
It is buried in the mixers noise and the waveform shown on the scope is the actual signal being sampled by the computer.
Sorry, I did not get a chance to test the Gigabyte 900XA-UD3 motherboard as it went off to its destination, But maybe at a later time I will do so.
The Asrock system is still running solid at 4.8GHZ and I only had one BSOD so far and I don't know what has caused it,other than that I have not had any issues so far.
I did get linux to install as it was a problem with the boot loader installer and the UEFI bios.
This has been fixed in more recent updates although it was a PIA to figure out the proper sequence to make dual boot system with Win7.
I am now trying out Ultimate Edition Linux 3.5 and it is a very nice build and I like it very much.
I am still learning how to work with linux and it's sound systems are confusing to me so at the moment I find it sub par for recording uses although it plays back nicely.
So as usual I stick with windows for audio functions until I can figure it out.
I will experiment with it more after I get my critical data that I have been sorting off of the only 1TB drive that I have right now.
I have found that running the Realtek ALC892 at 192Khz can be glitchy on the input side at times.
This is apparent while using Holm Impulse and REW5.0 beta10 and such during some sweep tests.
I would have to repeat several times the test until I got a clean sample and the glitched data was never in the same spot.
Now that I think about it this very well could be be an issue with my mixer as it has been know to do this as well.
I haven't heard these glitches except on playback and I wasn't monitoring the same output that is feeding the computer either, but, my scopes is, and I didn't see any glitches going in, so I suspect it is an issue with the ALC892.
It does not do this at all 96Khz.
Running at 192Khz is very cool and the bandwidth is extended to about 70Khz to 80Khz !!!
I already know that my mixer is good until 100Khz so this was very exciting for me.
I did find the the GINA24 card is a bit better with a lower noise level and flatter THD curve.
I didn't get any screen shots of that data as it is just a completely different class of caliber although the ALC892 is still a great chip.
Also the GINA24 can't do 192Khz either but I think it might in the 16bit mode only.
I have not verified this yet but some programs do accept the 16bit 196khz parameters when using it.
Enjoy !!!
jer
Old 16th January 2013, 10:34 AM   #46
using this part,
Thank you. My motherboard has a SPDIF header. I just want to bring out the digital. For any one interested I found a reference doc from Berkely U, including circuit design examples :
http://www-inst.eecs.berkeley.edu/~c...xplanation.pdf
Old 18th January 2013, 10:30 PM   #47
Just an update.
The ALC892 is flakey at 24bit 192Khz with some programs.
It seems to work fine in this mode in Audacity but in VA2011 I can get it to work sometimes and sometimes not.
Even in the windows control panel (win7) they mostly only have 16bit modes selectable with a 24bit option on the input.
This does not look right to me as I thought I remembered seeing 24bit modes as well when I first installed the system.
I know my laptop has these modes.
I will try XP64 and see if there is any difference some time later and post back.
jer
Old 21st January 2013, 02:19 AM   #48
You want an SOtM USB card then....as mentioned seperate boards with isolation are the preferred implementation.
Scroll down a few here
SOtM
Try to avoid ANYTHING else on the same Bus.
Old 21st January 2013, 02:38 AM   #49
I was just playing with an AMD Trinity A10 w. Hudson 3 (A75) chipset.
I'm gonna be upgrading an old Dell with an XP licence sticker and wanted
to test the board first with a live boot CD. Get some idea what the driver
conflicts will be when the "old" 1TB SATA XP drive sees new board and be
prepared the likely event it has to be re-installed. Oh joy, a nightmare...
Pain to boot XP (UBCD4WIN) or Knoppix 7, but can be done...
I had to find a setting in bios and set SATA to IDE mode for WinXP.
The default is "AHCI", requires you press F6 to load driver on floppy.
But this board DOESNT HAVE A FLOPPY HEADER! You either have to
hack your boot CD to include the driver, or use the SATA "IDE" mode
if your motherboard bios offers that option. If you don't know to do
that, XP is likely booting the blue screen of death...
Knoppix had no probs with IDE or AHCI. But the on chip video was
a scrambled mess every time. You need the cheat code: nomodeset
Took me several days trial to discover too...
Old 16th February 2013, 10:06 PM   #50
I am going to build a silent streaming computer. And i am wondering if any of you know of a motherboards that can be run without fan and has s/pdif output header that will do 24bit 192khz, so you dont need the a sound card with s/pdi?f 24bit/193kHz?
Is it correctly understood that the asrock motherborad mentioned above can do that?
Any other boards that can do that ?
I tink this might be the way to go for me :-)
Amplifier motherboard apexaudio Solid State 72 29th January 2012 02:22 PM
Motherboard capacitors jfitz57 PC Based 3 8th April 2011 08:50 AM
Nice motherboard DragonMaster Everything Else 1 4th February 2007 08:02 AM
Asus Motherboard herm Everything Else 5 3rd January 2007 10:11 AM
pc motherboard with audio tube karma Tubes / Valves 4 20th April 2003 10:07 PM
Copyright 1999-2017 diyAudio
