PC Based Computer music servers, crossovers, and equalization
uncompressed flac
uncompressed flac
Old 29th August 2012, 10:04 PM   #1
jamesfeline is offline jamesfeline  United Kingdom
jamesfeline's Avatar
Default uncompressed flac
Hi
I have given up trying to tag wav files 100% reliably, any one out their using uncompressed FLAC that is in the latest edition of DPpoweramp ripper
regards
Nick
Old 29th August 2012, 10:53 PM   #2
macboy is offline macboy  Canada
FLAC is lossless; there is no need whatsoever to use "uncompressed" FLAC. Just use FLAC. It is well supported, taggable, and sonically identical to the wav that it is created from.
Old 29th August 2012, 11:52 PM   #3
kevinkr's Avatar
uncompressed flac
Pretty much my entire digital music library is in FLAC format. (Some DSD)
FLAC is referred to as a lossless codec, not "uncompressed" - which in any event is incorrect terminology because FLAC losslessly compresses and restores audio files.
Try EAC for ripping, open source, free and one of the pioneers of error free "paranoid mode" ripping - it also can handle the conversion to FLAC or a number of other popular codecs.. (APE, Monkey's Audio [Lossless], Lame MP3, etc.)
I use J River Media Center 17 which handles just about every aspect of digital media management from ripping, tagging, album art, database management to obviously playback. It will play most media formats natively including DSD, and of course FLAC.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 30th August 2012, 05:35 PM   #4
Wink flac uncompressed
Hi
I am well happy, using the latest DP-Poweramp CD ripper with the latest uncompressed flac setting (basically it takes a raw wav file and wraps it in a flac wrapper for tagging)
and it sounds great ... and I have it playing in WMP 11 and 12 and windows media center as well as J river 17 media as well ... yes that's right WMP playing full flac files with artwork and tagging.
I finally have wav files with full tagging
yeepppeeeeeeeee
Old 30th August 2012, 05:39 PM   #5
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
uncompressed flac
And you will be even happier when you realise that you can choose a compression level (6 is what I use, think it's the default) and have files half the size with no loss of quality.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 31st August 2012, 01:12 AM   #6
onethree is offline onethree  India
I have my entire CD collection ripped to FLAC. FLAC is easily tagged (I use Tag&Rename) and also the SQ is on par.
I'd recommend using EAC for the ripping. Its free, fast and accurate.
Old 31st August 2012, 01:45 AM   #7
hazard500 is offline hazard500  Australia
I rip all my records at 192k/24 bit, average LP is 3gig - I then use foobar as a front end for flac conversion (flac front end doesn't work on my Windows 7 PC). This saves over 1 gig of storeage per LP, so helps me cram more LPs onto my 2TB drive.
Old 31st August 2012, 02:04 AM   #8
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Recording LPs with 24bits means a lot of what's stored on your drive is going to be noise and that doesn't compress at all.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 2nd September 2012, 10:55 PM   #9
With respect, I don't understand any of this - you seem to think that increasing resolution from 16 bit to 24 bit is bad for the sound?
Old 2nd September 2012, 11:25 PM   #10
john57 is offline john57  United States
Increasing the recording bit rate from 16 to 24 increases the dynamic range not detail. 96k sampling rate is all I need from a LP transfer to FLAC. At 192k/24 bit you are going to used much more space on the hard drive with no increase in detail. Depending on what ADC chip you are using can decrease quality at 192K as compared to 96K. For live recording I do use 24 bit so that I do not run into a situation where the sound could cause clipping in the recordings and then I usually will down-sample to 16bit for redbook standard.
uncompressed flacHide this!Advertise here!
RF remote control of UNCOMPRESSED WAVs? budget minded Everything Else 14 24th December 2009 10:15 PM
Any Flac aficionados around? Netlist Everything Else 7 16th December 2007 08:00 PM
FLAC on microcontroller gene_klein Digital Source 4 1st December 2007 02:44 PM
Uncompressed cd's Konnan101 Digital Source 20 16th January 2004 11:38 PM
