PC Based Computer music servers, crossovers, and equalization
TE7022+ES9023 mini toy^_^
Old 26th February 2013, 10:51 AM   #21
Beacon64 is offline Beacon64  Scotland
Beacon64's Avatar
Hi Yubing, arrived this am. Brilliant!
Old 28th February 2013, 08:27 PM   #22
Beacon64's Avatar
Default Adequate power
Probably obvious, but you have to ensure that the DAC has sufficient power to drive it well.
When I originally set up the DAC, it sounded awful.
I tried a series of drivers, with no success. I disabled other sound hardware with no joy. I moved it to an XP machine and it sounded much better. I then unplugged the USB keyboard on the Windows 7 machine and it began to sing!
For a low cost DAC, it is excellent over 'phones. I'm going to give it a few days to settle in, then compare it with the Netgear EVA9000. I suspect both could use improved power supplies. I feel a project coming on!
Old 1st March 2013, 12:32 AM   #23
ttan98 is offline ttan98  Australia
I recommend you download this software to check the latency of your system, it should be less than 500-600ms. Huge or continuous Red spikes in your system will cause music interruptions to your music.
Download DPC Latency Checker
Old 1st March 2013, 07:20 AM   #24
Beacon64's Avatar
Thanks, I'll do that!
TE7022+ES9023 mini toy^_^Hide this!Advertise here!
FS:Finished USB DAC - WM8741 & Tenor TE7022 diyhifishop Vendor's Bazaar 19 8th August 2016 08:24 AM
Info on Tenor TE7022? chaparK Digital Source 23 1st January 2016 01:46 AM
WEILIANG DAC5 - WM8741 & Tenor TE7022 dhalbakken Digital Source 396 10th August 2015 09:10 AM
ES9023 DAC PCB jean-paul Digital Line Level 212 23rd July 2013 12:45 AM
ES9023 DAC build heartwinter Vendor's Bazaar 8 7th July 2012 09:27 AM
