PC Based Computer music servers, crossovers, and equalization
Help needed in repairing Squeezebox Classic VFD
Old 18th August 2012, 08:51 AM   #1
rmgvs is offline rmgvs  Netherlands
Default Help needed in repairing Squeezebox Classic VFD
My question is simple and complex at the same time. I have spent several days searching on the internet and not found what I looked for.
It is about a Squeezebox Classic (V3 etcetera). Everything works fine except for the VFD display. I can pretty sure point to what causes the non-functioning of the display but am not able to pinpoint it to the exact location on the pcb (due to a lack of circuit diagrams for the V3, a shame since the player is not longer sold anymore, nor repaired for that matter, it seems like the SB's are seen as throw-away articles ...).
Sean Adams has made a block diagram of the different voltages of the SB3. It starts with the external powerplug (switched 5V). Inside this delivers 3v3 and 1v2 for IO, wireless, logic, CPU and headphone.
After the 5V it goes to a switcher and a multiplier too, where 11 VAC and 55 VDC are 'made' for the display and 14 VDC for the opamps and DAC. All these voltages are not available in my SB3 (I know what causes the failure but skip this for brevity).
It's easy to make a new 14 VDC for the opamp and DAC. There is one resistor of 100 Ohms (R45 on my pcb): take this out and apply an external 12-14 Volts at the big cap J2 and done. I'm amazed that this mod is not done more often by audiophiles. It has to be much better than all those expensive regulated 5V power supplies at the outside because anyhow after that there will be another switched component and other maybe no so audiophile stuff.
So after that everthing works as should except for the display. Now two options are open:
1. I can make another external power supply that delevers 11 VAC and 55 VDC. Question: which pins of the VFD are for what voltages? And: is there a simple circuit available that delivers both voltages starting from a small 12 vac transformer (ie some kind of Cockcroft-Whalton circuit that already had been used in the existing circuit)?
2. (This is the preferable option) I don't know where to start. The VFD is allright. It's only about the supply of proper voltages. Because the initial 5V is allright, the problem has to be in the internal switcher and/or the voltage multiplier (and/or in a connecting component for example a resistor that connects the stages). So (after 6 years of existence and ten thousand hours of worldwide modding these things) who can tell me which component on the board is the switcher and which is the multiplier (this must be the string of diodes D9-D13 with associated caps?). And what is the most probable component of break down due to a temporary burst in (too much) current?
Thinking along with me will be appreciated. These SB's are way too good to throw away after 3-5 years of operation.
Old 23rd August 2012, 02:12 PM   #2
Default Nobody a clue?
I'm still waiting for some light into the matter.
In the mean time I've not stood still. I have 'mastered' net-udap which was brought to the Squeezebox community as a Perl-based tool to install the SB Receiver without needing a remote controller.
The tool works for a number of other SB's too. Normally there is no need to work with udap since all other SB's have screens to do what is needed. But not in my case where the screen has no power and refuses to shine.
I figured out how to feed all necessary settings into the Classic. I first made a script into a text-editor so that I could experiment easily. With copy and past I move all commands to the udap-tool, reset the Classic and in the end it worked.
Next I disabled the normal remote because this is confusing without screen.
Conclusion: now I have some kind of Duet-receiver without screen that looks at the outside like a Classic. It can be controlled with Iphone and Ipad etc.
But all ideas about getting the screen alive I welcome.
Old 5th June 2013, 04:47 AM   #3
restoreman is offline restoreman  United States
Hi rmgvs,
I had exactly same vfd supply problem, that I was thinking of fixing by replacing internal switcher with external supply(ies). But eventually I ended up fixing the internal power supply.
If you are still interested, I can send you the process, but I need to document it first.
Essentially I replaced the switching transistor, switching ic, and the filter cap. The ladder diodes were ok - can be verified easily with a multimeter.
The switching transistor in smps was blown. Hence I changed it -> it was blown up again. Then I searched for the switching ic, I think I got it from littlediode uk. Changed the IC - but no luck. Then I ripped off the condenser can (without damaging the pcb !) and replaced it with a through hole type capacitor - and that was it .... my sb3's vfd was shining bright again!
It all looks easy and straightforward now - but those were many long frustrated nights. I almost sat on that VFD issue for 5 months. I had even ripped of the VFD to check filaments!
Now I am the luckiest person on the earth - my sb3 just works fine that I have hooked up to a raspberry pi and the output is hooked to yamaha rx-z1 with yamaha mx-1000 for the front right and left channels.
I control SB3 using android phone(s) and also kindle fire HD.
The system sounds so great -- I had never achieved that audio quality in my life. (My first tube radio fix was about 30 years ago!)
Do let me know if you want photos and detailed explanation - but try it ONLY IF you are good at SMD (de)soldering.
-restoreman
Old 13th June 2013, 09:50 PM   #4
stormsonic is offline stormsonic  Slovenia
stormsonic's Avatar
-restoreman
Yes please, I'm interested
Old 14th June 2013, 06:35 AM   #5
Default Yes i am
I am interested too. Still have not solved the issue. Looks like you are the first person who has delved that deep into the matter and succeeded too.
Please send me the pictures + explanation.
Old 25th July 2013, 12:46 AM   #6
Moffutt is offline Moffutt
I would be very interested in instructions and drawings/pictures for this
Old 27th July 2013, 03:23 AM   #7
pedrocols is offline pedrocols  United States
I would also be interested before I trash mine please. Thank you!
Old 19th August 2013, 10:48 AM   #8
Default mr restoreman, where are you?
No signs of live of mr restoreman yet? I've mailed him in person but no reaction yet. Well, I'm still interested so let's hope he will bring us the instructions.
Old 11th November 2013, 10:21 AM   #9
MegaMav is offline MegaMav
YGPM
Old 1st February 2015, 03:26 AM   #10
Its the electrolytic cap 22uf 63v after the ladder. That dries out and then tripps the switching power supply. Try replacing the 22uf 63 v cap with normal through hole type if you u dont have surface mount type. I have two sb3s and i changed that cap on both.
Help needed in repairing Squeezebox Classic VFDHide this!Advertise here!
FS: Squeezebox Classic igor0203 Swap Meet 1 11th June 2012 05:00 PM
Advice needed re repairing Audio Research VT100 Zoodle Tubes / Valves 4 23rd February 2011 10:08 AM
Repairing a NAD 2200 Poweramp. Advised needed. owens Solid State 2 14th October 2010 01:49 AM
Phoenix gold xs2300 - advice needed for repairing fbc Solid State 3 6th February 2010 10:27 PM
Help needed repairing HK Citation 12 Buhl Solid State 15 5th September 2005 01:56 PM
