Need help designing a circuit for my carpc. - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 28th July 2012, 10:04 PM   #1
Default Need help designing a circuit for my carpc.
Mac Mini
TO
Analog output, 3.5mm plug split to L/R RCA
TO
Ground loop isolator
TO
Circuit Box, L/R RCA inputs, hardwire splits the 2 inputs to four outputs, and 5v is applied to all the negative feed lines.
TO
Monsoon Amplifier
Circuit requirement: Monitor the audio feed and when there is a signal turn on the 5v feed. When there is no audio signal turn off the 5v feed.
Why?? I'm sure you are wondering why in the world I would inject 5v into the negative lines feeding the amplifier. Well I did not design the Monsoon Amp and whoever did decided a seperate turn on circuit was too easy. So, to turn on this amp 6v is injected into all the lines +/-/L/R/F/B. Through reading and testing I have found that 5v on the left front negative line turns on the amp. But there is a buzz. 5v applied to all negative lines eliminates the buzz. When audio feed is off there is a buzz.
So, I want a circuit that monitors the audio line for a signal and then turn on/off the 5v feed accordingly.
Caz
Old 30th July 2012, 03:39 PM   #2
Pac Audio TR-4, TR-7, and TR-7 Pro should do the trick.
Feel free to send me some help though.
Re-designing 6DJ8 circuit for the 6CG7 lordearl Tubes / Valves 31 16th June 2012 08:34 PM
Designing a Tube Rectifier Circuit Ducs Tubes / Valves 3 18th April 2012 06:35 PM
help designing a Linkwitz Transform circuit blrh93 Full Range 4 3rd November 2008 11:59 PM
Printed circuit board designing? flyinglemur Tubes / Valves 11 23rd March 2008 12:41 AM
PCB layout n circuit designing tanvicarrier Parts 0 12th August 2004 04:22 AM
Copyright 1999-2017 diyAudio
