PC Based Computer music servers, crossovers, and equalization
windows problem
windows problem
Old 13th July 2012, 11:16 PM   #1
zuki is offline zuki  United States
Default windows problem....
in my windows xp under control panel. sounds and devices
i am unable to set the volume of the mic at level 1.
it just shows a range from min to max.
but no numerical value.
Old 19th July 2012, 06:54 PM   #2
LAJ is offline LAJ  United States
Default Is the sound card working?
Could be adjustable gain is not available on that particular sound card.
Just a thought.
Old 19th July 2012, 07:15 PM   #3
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
windows problem Send a message via Yahoo to vdi_nenna
At the bottom right near the clock, do you see a speaker icon for audio settings? If you right-click it, select Open Volume Control, you see the mixer with a list of controls.
This would be more than just the volume control. Mic input should be on of the options. If it not an option, select Option at upper left and select, then Properties. Look for a list of available volume controls. Find Mic in the list and check it. Also check off Advanced to see more settings by going back to Options at the top of tool bar.
I build, therefore I am.
Old 19th July 2012, 07:29 PM   #4
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros windows problem
set it to minimum, then press once, the arrow key that will increase the value.
I suspect minimum is '0'. Zero what though is another discussion (Zero gain? Zero level?)
Old 8th September 2012, 03:54 AM   #5
sanbadgujar is offline sanbadgujar  India
Hi all how to make fast installer Win Xp cd with some software inbield please anyone know
windows problemHide this!Advertise here!
Problem with Jack Audio for Windows and Numark DJ/IO emzero PC Based 1 27th May 2012 02:55 AM
Windows 7 Theo404 Everything Else 110 9th November 2011 04:17 PM
Windows 7 subwoofer problem bobbobn PC Based 0 16th July 2011 02:19 PM
Odd Windows XP boot problem woody Everything Else 4 11th January 2009 11:52 PM
Copyright ©1999-2017 diyAudio
