diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   PC Based (http://www.diyaudio.com/forums/pc-based/)
-   -   Unbalanced pc to balanced qsc mx700 (http://www.diyaudio.com/forums/pc-based/215157-unbalanced-pc-balanced-qsc-mx700.html)
erichthinks 25th June 2012 11:20 PM
Hi guys.
I need some help. I can usually trial-and-error my way out of a jam, but I'm a wiring design novice. This simple problem comes down to the following:
1. I have a 3.5mm unbalanced TRS stereo output (PC, ipod, what have you).
2. I have a QSC mx700 from ebay. Its manual here:
3. The QSC uses a 5-terminal barrier strip, or two balanced mono TRS inputs.
Which method should I use to connect? I can't make definitive heads or tails out of the manual, it assumes a greater knowledge of signal behavior than what I have.
Thank you for any links or shared experience you may have. Sorry if this is uber-nub.
dangus 26th June 2012 01:04 AM
The manual says "When making unbalanced connections, the unused terminal must be grounded for proper response." So, regular mono 1/4" plugs should do that for you, but the signal will be inverted. If polarity matters, use 1/4" stereo plugs, make the ring "hot" and ground the tip to the shell. So, the simplest solution is a 3.5mm to RCA cable, then two mono RCA to 1/4" cables.
Resources saved on this page: MySQL 18.75%
