PC Based Computer music servers, crossovers, and equalization
noise from laptop charger
Old 24th June 2012, 11:39 AM   #1
pforeman is offline pforeman  United States
Default noise from laptop charger
I get kind of a white noise that "rolls and bumps" from my stereo when the laptop is connected and the charger is connected to it.
Is it commonly necessary to build a better charger for the laptop to eliminate this.
Is this what I should do?
Thanks,
Paul
Old 24th June 2012, 12:12 PM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Most reasonable sound cards will filter this noise out.
Try a good USB Sound card first as it's not realy practical to eliminate all the noise from a poor Lappie.
Old 24th June 2012, 12:57 PM   #3
powerflux is offline powerflux  Netherlands
disconnect the safety earth pin/use an un-earthed extension cord, you're experiencing typical ground loop issues.
Old 25th June 2012, 02:22 PM   #4
marce is offline marce  United Kingdom
Thats a bit dodgy.
It sounds like an EMC problem, what frequency is the noise approx.
Old 25th June 2012, 02:27 PM   #5
well, it's an easy test. just use an un-earthed extension cord or adapter and you'll know without making any modifications..
Old 25th June 2012, 10:28 PM   #6
dangus is offline dangus  Canada
It could be the charging circuits in the laptop generating noise, in which case nothing you can do to the external power supply will help. The external supply is nearly always just a plain power source. There's internal chips which monitor the battery voltage and temperature and limit the charging current and voltage so the battery doesn't go boom.
Use a USB or PC Card sound device. Or a USB headset; Microsoft's "Lifechat LX-3000" sounds extremely good for the price (often under $20 if you catch the right sale). I bought them a few years back, and they were comfortable (in spite of my large head) and sound good. Going by recent Amazon reviews, it is possible that Microsoft has let the quality slip. You could always wire up to an inline jack and plug in a different headset or headphones if the original headset breaks.
noise from laptop chargerHide this!Advertise here!
Eliminating Battery Charger Noise in DIY Stereo scwhiteley Power Supplies 15 20th August 2010 08:53 AM
Strange DC offset with laptop audio output and some noise. Corben PC Based 0 16th December 2009 08:17 AM
Noise on laptop charger PSU NinjaKitten Power Supplies 9 17th January 2009 05:21 PM
