Any external soundcards with PCM4202? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 19th August 2012, 05:02 PM   #11
dirkwright's Avatar
Originally Posted by s3tup View Post
Why not the PCM4222EVM? PCM4222 and PCM4202 are rather similar...
For 192kHz/24bit SPDIF input into PC - get the Infrasonic Quartet.
I'm interested in the PCM4222EVM also but do not know how to interface the AES or S/PDIF outputs (or the DSD output) to my laptop with firewire and USB. There doesn't seem to be a box out there that does that.
Would this work:
http://www.twistedpearaudio.com/digital/usb.aspx
If you connect the PCM4222EVM S/PDIF output to this board it converts it to USB. I just don't know enough about digital audio to know for sure. The TI DAC used in the Twisted Pear board is only good for 16 bits/48kHz. crap.
Old 19th August 2012, 05:37 PM   #12
s3tup's Avatar
Nah, it won't work. They call it "receiver" as it receives "USB" and turns it into "SPDIF" or whatever. No SPDIF input.
Check out the miniDSP boards, there are some interensting, much better than beaten-to-death PCM thing.
I guess the TE7022 board should work up to 96k/16bit (or maybe even to 96/24), but you'd better ask them to be sure.
If you want 192kHz... then i'm lost (had to buy PCI card to make it work).
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 19th August 2012, 07:19 PM   #13
dirkwright's Avatar
Do you mean this board?
miniSTREAMER | miniDSP
It does look really good. thanks!
The PCM4222EVM board's serial output can be configured for I2S output, which can be connected to this minidsp board, or I could use one of the S/PDIF outputs for the minidsp board also. Ideas?
Old 20th August 2012, 10:17 AM   #14
I've found this as well:
Welcome - Rigisystems
the USBPAL allows for 384 kHz/32 bits both ways and actually also for up to 1.536 MHz/32 bits, although I haven't yet been into how this is configurated.
Best regards,
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 20th August 2012, 01:27 PM   #15
dirkwright's Avatar
Best regards,
Jesper
Whoa, that looks really nice. I bet it's not cheap though. Can you get a price?
Old 20th August 2012, 09:16 PM   #16
Hi Dirkwright,
The prices actually are on their website:
USB Audio - RigiSystems AG
.. at the bottom. I don't know though what the basis kit includes in terms of the RDK or SDKs for development.
Best regards,
Jesper
Old 21st August 2012, 03:55 PM   #17
dirkwright's Avatar
Hi Dirkwright,
Best regards,
Jesper
OK, thanks. Too rich for me right now. I bought a miniStreamer from MiniDSP. It has I2S input and output to USB. I am hoping to connect the audio serial port on the PCM4222EVM to the miniStreamer for output to my laptop. Do you think this will work. Pete's interface will come in handy interfacing the audio gear with the PCM4222.
Old 22nd August 2012, 03:39 PM   #18
Hi, I'm not really a digital expert but from briefly reading on miniDSP's website it appears to accept I2S at 96 kHz and the PCM4222 outputs I2S as well. You apparently won't be able to use 192 kHz, though. When connecting things you should consider short distances, good cabling etc. - but maybe you already know this ...
Best regards,
Jesper
Old 22nd August 2012, 04:21 PM   #19
dirkwright's Avatar
Best regards,
Jesper
Yeah, I know that the miniStream is limited to 96Khz. They have a more expensive one that does 192kHz. I was going to put both of them in the same box, so the connection would be just some short jumper wires. Here's a photo of the evaluation board. It apparently has awesome performance.
Old 30th January 2013, 01:27 AM   #20
Telstar is offline Telstar  Italy
Hello, I'm also considering the pcm4222 evaluation board. From a quick read of the manual it is limited to 192khz, but can output in i2s format, other than spdif AES/EBU.
The usbstreamer seems the cheaper option available, although i2s connection must be short.
The best "sound card" usb interface I found is the yellowtec puc2 lite, which is only Aes in/out and the drivers and general build quality seems high. Cost is almost 400€, though.
Opinions? Someone else managed to interface well an ADC to a computer for audio measurements?
My reluctance of using just an emu 0204 or even the qa400 is the poor HF performance which makes them unusable above 30khz (when set at 192k)
I would like to do a 20k fft properly, and 19+20k imd.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Using 2 soundcards merlinx76 PC Based 1 1st April 2011 08:46 PM
Best audiophile Soundcards ostripper Digital Source 3 18th August 2008 03:51 PM
soundcards exurbia Digital Source 10 13th August 2008 06:06 AM
simple question about soundcards VEC7OR Everything Else 0 19th December 2003 06:16 PM
Soundcards JoeBob Digital Source 21 22nd January 2002 08:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
