| PC Based Computer music servers, crossovers, and equalization |
#81 |
Thanks Chris
I will try tomorrow on another Laptop, who knows ? BR |
#82 |
I would say the soundcard has the volume at max (127, 100%), but is muted (off)
Code:
Card hw:1 'L20'/'Luckit Luckit USB Audio 2.0 at usb-0000:00:1d.7-1, high speed' Mixer name : 'USB Mixer' Components : 'USB20a0:4143' Controls : 4 Simple ctrls : 2 Simple mixer control 'Luckit Clock Selector',0 Capabilities: pvolume pswitch penum Playback channels: Front Left - Front Right Limits: Playback 0 - 127 Mono: Front Left: Playback 127 [100%] [0.00dB] [off] Front Right: Playback 127 [100%] [0.00dB] [off] Simple mixer control 'Luckit Clock Selector',1 Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum Playback channels: Mono Limits: Playback 0 - 127 Mono: Playback 127 [100%] [0.00dB] [off] |
#83 |
I would like to try mpdpup but I can't find how to even start getting a copy, never mind installing it. Any links please?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#85 |
Hi all
At least succeeded to check my WaveIO USB board, my PC, my file share, my Slacko Puppy and get Alsamixer working with a little help from my friends. Thanks to all who contributed. I've learned a lot, but still more to come ! I'am going now to work on my mpdpup distro I could not get up on my first trials, with much more confidence, and try to compare with slacko and why not other distros in the future. Next step : the remote (;-) BR jean-Louis |
#86 | |
Just one tip : do not save the config file on another device than the one where your distro is installed (probably the SD or CF Card). It killed my first attempts
#87 |
When I go into the console and type in a play-l, I get a list of the sound cards, including the USB device that I am using.
But when I type in #!/bin/bash # script to outout the audio sample rate from card1/0 # usage example: sr 0 1 (where 0 is your card of choice and 1 is the subdevice) cat /proc/asound/card$1/pcm0p/sub$2/hw_params I get the message 'No such file or directory'. And I haven't even found how to change the output yet.
#88 | |
Save the following to a file called "sr" in your /home/<username>/bin directory Code:
#!/bin/bash # script to outout the audio sample rate from card1/0 # usage example: sr 0 1 (where 0 is your card of choice and 1 is the subdevice) cat /proc/asound/card$1/pcm0p/sub$2/hw_params Then you can run "sr" and give it the two numbers (card # and subdevice) of the card you want to get the details on like this: > sr 0 0 (with spaces)(for card 0 subdevice 0) (the $1 and $2 are inputs with the command) |
#89 |
Thanks for your advice MrSlim but I'm afraid that I've given up with Slacko as I can't even get it to load any more. I get the message
'Kernal panic - not synching' and it hangs there. Free is nice (and I am grateful for the efforts of those who create this type of software) but all too often it involves an unacceptable learning curve, and huge loss of time. I'll be waiting for a Linux version that works, and can be optimally set up via a user interface that doesn't involve knowing how to program.
#90 |
As your first encounter with linux you chose a niche distribution aimed at very experienced users with very specific requirements. Your effort was going to fail from the very beginning.
| Linux Audio the way to go!? | soundcheck | PC Based | 2128 | 29th April 2013 08:53 AM |
| Wilson Audio Puppy Clone | InfinityPWS | Multi-Way | 1 | 26th January 2006 07:37 AM |
