PC Based Computer music servers, crossovers, and equalization
Dummyś  guide for audio with SLACKO puppy linux os
Old 28th August 2012, 12:55 AM   #41
kp93300 is offline kp93300  Malaysia
Hi
I disabled the on board sound card in my pc.i do it via the bios setting.
I have switched over to linux mint 10 for a while because it sound better and more flexible. I do not have to configure the sound card at all.
Just download the OS and burnt it as an iso into a CD rom.
cheers
kp93300
Old 28th August 2012, 07:23 AM   #42
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Thanks kp93300 - I'll give that a try too.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 28th August 2012, 04:07 PM   #43
Nuuk's Avatar
Today I have tried Slacko on a laptop instead of the older PC that I used yesterday, and it works! Sounds quite different to Ubuntu/Exhaile, and of course different to various configurations with Windows. Where will it ever end?
Old 29th August 2012, 10:35 PM   #44
JLOP is offline JLOP  France
Hi Nuuk
How different does it sound to windows & Ubuntu ?
Old 30th August 2012, 07:29 AM   #45
Nuuk's Avatar
Originally Posted by JLOP View Post
Hi Nuuk
Quite a bit but keep in mind Ubuntu is on a much older PC with 500 meg of RAM, and Slacko is on a more modern laptop with 2 gig of RAM.
On Slacko it sounds slightly 'darker with less background noise. There's a bit more detail too probably due to lowering the noise floor. On Ubuntu, the sound is more 'airy'.
Old 30th August 2012, 09:02 AM   #46
gk7 is offline gk7
Originally Posted by Nuuk View Post
... with less background noise. ...
Did you measure that ?
Old 30th August 2012, 09:23 AM   #47
Nuuk's Avatar
Yes -with my ears. It was audible.
Old 30th August 2012, 09:23 AM   #48
phofman is offline phofman  Czech Republic
Different hardware will doubtlessly produce different sound, regardless of the software. If both distributions running on a single hardware are configured to be bitperfect, I very doubt you would be able to distinguish which one was booted in a blind listening test.
Old 30th August 2012, 09:41 AM   #49
soundcheck is offline soundcheck  Germany
It'll never end until somebody develops a bloody DAC that is immune on PC induced distortions (noise and jitter).
The issues are known since years.
I started my "Linux Audio the way To go" thread in January 2007.
Nothing has changed ever since. People are still tweaking the PCs to get best sound from the DACs.
Though I have to admit: You can tweak any other OS that much that results are getting really close. I'm not sure if SQ would still be the driving factor to stay with Linux.
Linux/Android still comes with worst audio driver (and tools) support, as well as pretty poor application support. (You still can't buy a DAC of choice, if you run Linux. You buy what's supported). I still hope that driver support gets better with Android gaining weight.
To be honest. Beside my squeezebox environment which runs under Linux, I use JRMC - IMO the best multimedia app around. And with ram buffering and
wasapi event style it sounds pretty good too. You might run Fidelizer to tweak to W7 environment.
But again. An OS or an app or a PC shouldn't sound at all. The DAC only should make the music.
Old 30th August 2012, 09:44 AM   #50
Nuuk's Avatar
Well if you get the chance, try JPlay on W7/W8 and compare it with JRiver Jukebox on the same machine.
Dummyś  guide for audio with SLACKO puppy linux osHide this!Advertise here!
Linux Audio the way to go!? soundcheck PC Based 2286 24th June 2016 09:50 AM
Wilson Audio Puppy Clone InfinityPWS Multi-Way 1 26th January 2006 07:37 AM
