PC Based Computer music servers, crossovers, and equalization
Dummyś  guide for audio with SLACKO puppy linux os
Old 6th November 2012, 10:48 AM   #91
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Originally Posted by phofman View Post
As your first encounter with linux you chose a niche distribution aimed at very experienced users with very specific requirements. Your effort was going to fail from the very beginning.
I've been using Ubuntu for four years now, so it was hardly my first encounter.
In the past I programmed in Basic and machine code, so I'm not exactly a complete novice.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th November 2012, 11:30 AM   #92
phofman is offline phofman  Czech Republic
Then you should be able to work out the problem with just a bit of effort. BTW, google is your friend and searching for error messages almost always yields a direct answer.
A simple search for https://www.google.cz/search?q=Kerne...+-+not+syncing shows that error message is followed by a description of the kernel panic cause. Further search for the complete error message will most likely give you the answer.
Old 15th January 2013, 02:18 AM   #93
gychang is offline gychang  United States
Originally Posted by Nuuk View Post
Look out for somebody getting rid of an older computer, add Slacko and a HiFace Two with a good DAC, and you have a budget hi-end source for no more than a mid-range CDP would have cost a few years back, but sounding oh so much better.
I have a pentium 4 PC idle, and will try this.
I am not familar with HiFace: Amazon.com: M2TECH hiFace Hi-End S/SPDIF Output Interface with RCA connector - EHIFACER: Computers & Accessories at $159, seem rather steep. I have a turtlebeach audioadvantage micro (older model) that plugs into USB port and output to optical as pictured (works as DAC). I have t-amp/speaker combo so I will try this. I am unsure if TB micro will be supported natively in linux.
by the way if my TB micro does not work, as recommendation on DAC?, do I have to have HiFace if I buy external DAC?
gychang
Good sound from Davis, CA
Old 15th January 2013, 08:26 AM   #94
Nuuk's Avatar
gychang
Only if the DAC does not already have a USB input.
Old 16th January 2013, 01:47 AM   #95
Originally Posted by i2k92 View Post
I also found another Puppy distro which is pre-customized as music server and can run from USB drive: mpdpup. I was about to test it last weekend, but could not be done due to other matters.
tried mpdpup, being not so linux smart, I got to mpd configuration (using usb stick boot), but can't seem to use my local HD as music storage. get confused with /mnt/music folder.
I may put in modem and see if I can get the another home linux PC (running crunchbang) folder be used as flac storage...
gychang
Old 16th January 2013, 01:54 AM   #96
Originally Posted by kp93300 View Post
Hi i2k92,
can i install the mdp pup on a a local harddisk that is also the storage device ?
kp93300
I tried to use local HD as storage with USB memory stick as boot, but failed... not linux-savy.
can one of the mpdpup guru make a youtube video?
Old 16th January 2013, 02:01 AM   #97
Originally Posted by thisisvv View Post
Thanks...thats what ia m looking for...i just got an pentium 4 1gb with no hard drive ...i hope to run this OS from USB hope can be done...
like to do this...
Old 16th January 2013, 02:08 AM   #98
Originally Posted by JLOP View Post
Hi Linerds
At the end of the day, what is the difference between Slacko Puppy + MPD and mpdpup ?
Kind regards
jean-Louis
Slacko is Puppy derivative that is versatile, internet etc..., where as MPD seems like strip down OS mainly for media playing... I prefer MPD but having difficulties...
Old 17th January 2013, 06:40 PM   #99
JLOP is offline JLOP  France
Default support for mpdpup
Hi gychang
If you have problem with the mpdpup, you'd better look for support on the original thread Puppy Linux Discussion Forum :: View topic - mpdPup - Simplified MPD Music Server/Jukebox - v0.9.3 where Idolse and many others will help you. They did for me to solve minor issues and now works very very well.
For the other question, you do not need necessarily a hiface, any USB to SPDIF will work, some better, some less. WaveIO is recognized as an excellent interface.
Good Luck
Dummyś  guide for audio with SLACKO puppy linux osHide this!Advertise here!
Linux Audio the way to go!? soundcheck PC Based 2286 24th June 2016 09:50 AM
Wilson Audio Puppy Clone InfinityPWS Multi-Way 1 26th January 2006 07:37 AM
