PC Based Computer music servers, crossovers, and equalization
Problem with Jack Audio for Windows and Numark DJ/IO
Old 15th May 2012, 11:34 PM   #1
emzero is offline emzero  Argentina
Question Problem with Jack Audio for Windows and Numark DJ/IO
I need to use Jack to be able to route Traktor's output to a VST host so I can apply any VST effect.
I've followed the instructions provided here: Using JACK on Windows | JACK
I've edited the shorcut's Target as follows:
Code:
"C:\Program Files (x86)\Jack\jackd.exe" -R -S -d portaudio -d "ASIO::Numark USB Audio Device" -r 44100
"ASIO::Numark USB Audio Device" is a valid device listed when running the command: jackd -d portaudio -l
Code:
-------- device #18 ------------------------------------------------
[ Default ASIO Input ]
[ Default ASIO Output ]
Name                        = ASIO::Numark USB Audio Device
Max inputs                  = 0
Max outputs                 = 4
ASIO minimum buffer size    = 512
ASIO maximum buffer size    = 512
ASIO preferred buffer size  = 512
ASIO buffer granularity     = 0
Default sample rate         = 44100.00
But when I run the shortcut to start the JACK server I get the following:
Code:
jackdmp 1.9.8
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2011 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
AudioSM::initAudioSM nChannels:0 nFrequency:0
AudioSM::init nChannels is 0
Allocate: named semaphore already exist name = jack_pipe.default_system
Can't open ASIO::Numark USB Audio Device, PortAudio will use default input devic
e.
Pa_OpenStream error -9993 = Illegal combination of I/O devices
Can't open default PortAudio device
Cannot initialize driver
JackServer::Open() failed with -1
Failed to open server
Also, if I try to use Jack Control Setup to select the Input/Ouput, when I click in the arrow that popups the device list, the program crashes.
Any ideas?
My setup is:
-Core2Duo 2.2ghz
-4gb RAM
-Windows 7 x64
-Numark DJ/IO USB soundcard
Old 27th May 2012, 02:55 AM   #2
loninappleton is offline loninappleton  United States
Well I don't know jack about this ;-) and haven't tried to apply the Jack program since experimenting with Linux a couple years ago.
A 'wrapper' may be needed as it is to apply VST effects.
Example, the free George Yongh 'wrapper' provides the ability to install VST effects.
A more common (but costly) wrapper is Cubase which is a pay-for program.
I don't know jack about Cubase either. But it's better than getting no answers at all.
I think Doom9 is a good place to address these crossover questions between Linux and Windows.
My system
AMD Athlon II x3 450 Regor 3.2 Ghz
MSI 880GM-E41 mainboard
Kingston DDR3 Hyperx/fb 2x2Gb
Seagate Baracuda 160Gb IDE HD
no outboard audio card.
Problem with Jack Audio for Windows and Numark DJ/IOHide this!Advertise here!
Numark DJ mixer sounds awesome in 'phones with MP3 player Rickh57 Everything Else 0 29th September 2011 08:47 PM
Jack For Windows Output Config Goto PC Based 5 29th August 2011 04:28 PM
Windows 7 subwoofer problem bobbobn PC Based 0 16th July 2011 02:19 PM
Numark CDN-22S transformer problem poynton Digital Source 2 23rd December 2010 06:49 PM
