High-level system design question - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 14th May 2012, 03:05 PM   #11
vputz is offline vputz  United States
Mayhem-- since the HTPC will be Linux based, both bluray and streaming services like netflix can be problematic, plus I do (very rarely) actually use the silly console for gaming. So it's just easier if I have the ABILITY to switch to an external source like the PS3.
Still looking at the 1010; they occasionally show up on ebay for a reasonable price. Not much time to invest in this at the moment, though, so we'll see.
Old 14th May 2012, 11:57 PM   #12
Look into pro audio interfaces, you're on that track anyways looking at the M-Audio. Multi-outs and ins, sp/dif, firewire, usb, etc. Depending on how the software is setup they can switch between sources. Better sq and build quality than a typical soundcard as well IMO. Definitely more $$$ ($500+) though and then you need to make some cables........not sure what works with Linux.
I just received a 12-channel interface from Echo Audio, super easy to setup and a solid unit. Purely analog in and out, though they do have other models with more connectivity. Solid driver support as well.
Last edited by natehansen66; 15th May 2012 at 12:25 AM. Reason: didn't see linux req
Old 15th May 2012, 07:12 AM   #13
phofman is offline phofman  Czech Republic
I have just used an old parallel port switch data port switch | eBay to make a simple integrated aplifier (tripath) with input selector. Those boxes contain a nice 3/4 x 24 rotary switch. Capable of switching 24 channels at once :-) Serial port switches can do 8(9?) channels.
Maybe this is the way to go, instead of fighting the sound card route :-)
Old 15th May 2012, 07:33 PM   #14
I like the idea, phofman, but since I was hoping to use the PC as preamp, I wanted to do the switching (and maybe 5.1 decoding) in software. This would at least let me use a "single line in" to the sound card and switch between inputs that way, but I'm going to toy with the idea a bit more just in case...
Old 11th June 2012, 12:14 AM   #15
nowhere is offline nowhere  Israel
Since this is a DIY forum - why not build a relay-based switching board controlled from, say, parallel port ?
Trivial in both HW and SW senses.
Old 15th January 2013, 12:21 PM   #16
Curious if you went with the 1010LT.
(minimal) speaker level vs. line level high pass filter noviygera Analog Line Level 1 15th October 2011 09:43 AM
Question about system design with the K-12 irishbk Tubes / Valves 18 16th February 2008 06:47 PM
Need High level, high pass crossover for 250watts Anthrax Multi-Way 0 21st January 2007 03:34 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
system level design stuff, i am garlic. theChris Chip Amps 3 8th February 2004 08:25 AM
Copyright 1999-2017 diyAudio
