Sound Card Input Circuit Protection - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 26th April 2012, 01:04 PM   #1
Default Sound Card Input Circuit Protection
I was wondering what the consensus is on protecting the inputs of PC sound cards from overvoltage/current. I am looking for a cheap, effective solution. The only one I have seen that meets this criteria, is a 5.1v zener in series with a 100 ohm resistor from output to ground. The max input voltage of the ADC is 5v.; Creative refused to provide the max current spec., but my research indicates it quite low, and there is a current limiting resistor already in the card.
One person argued, "The current needs to be limited, not the voltage." But limiting the voltage will limit the current, so it appears a matter of semantics.
Obviously, this theoretical protection circuit cannot introduce any detrimental noise. Would the presence of a zener do this? How about a varistor?
Old 26th April 2012, 01:32 PM   #2
Series resistor followed by a parallel Zener is good protection.
A resistor ladder attenuator in front will give a more flexible input controller.
Always start with the highest attenuation. Much as you did when Multimeters were analogue.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th April 2012, 01:45 PM   #3
I cannot visualize the "series resistor/parallel zener circuit. Additionally, the mic impedence should remain around 600 ohm. Hence the attraciveness of the clamp.
The ladder attenuator is good for testing. I am looking for a permanent addition to the mic circuit.
Old 26th April 2012, 02:05 PM   #4
Is the sound card input a mic compatible input for 600ohms microphone? I doubt it.
The Zener is in parallel to the input impedance. i.e. across or between signal and return.
The resistor is in series with the signal. i.e. fitted in line with the signal.
regards Andrew T.
Old 26th April 2012, 02:20 PM   #5
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I prefer to use two zeners in reversal series to short both negative and positive signals.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 26th April 2012, 02:20 PM   #6
Thank you for the clarification.
600 is the number given by Creative.
Old 26th April 2012, 02:22 PM   #7
Thanks. True indeed. I may actually have overlooked that!
Old 26th April 2012, 09:10 PM   #8
Simon B is offline Simon B  United Kingdom
Your reverse series zeners shouldn't start making much noise til they start conducting, so no problem there. They will add a little non-linear capacitance, but across a 600R input unlikely to be a problem.
I'm not sure what sort of peak voltages you want to protect against, or from what sources, but one scheme would be much as suggested so far:
Reverse series zeners across the soundcard input, (limiting voltage). Series resistor, 100R, between the protection input and the soundcard (limiting current through zeners during input overload).
If you want the impedance looking into the protection input to be 600R, rather than 700R, though I doubt it will be vital, a parallel resistor, 3k0 across soundcard input (ie parallel with the reverse series zeners) restores it to 600R.
The soundcard will see an apparent source impedance of:
3k0 // (100R + Zmic)
which should not be a problem
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 27th April 2012, 09:42 AM   #9
The Zeners will conduct in the forward direction starting from ~400mVpk. You will need diodes to block this forward current.
regards Andrew T.
Old 27th April 2012, 11:18 AM   #10
Any conduction before the zener voltage may be a problem. However, the zeners are back to back, in series, so in any polarity of potential, one of the zeners will be reversed biased.
I have yet to consider the specifics of component operation to that degree, so I do not know precisely what behavior the pair will demonstrate, except the pair will clip at about .7v above rated zener voltage.
Would not the introduction of standard diodes defeat clamping operation?
Turn off the mic input on your sound card boris81 PC Based 0 6th September 2011 10:23 PM
What is the sound card with the best input that you know of? wwenze PC Based 8 4th February 2011 11:02 PM
Sound card input voltage range? J.R.Freeman PC Based 6 17th March 2010 10:16 AM
sound card input levels maylar Solid State 3 28th April 2004 11:50 AM
sound card mic input JBL Digital Source 4 25th November 2002 06:16 PM
Copyright 1999-2017 diyAudio
