| PC Based Computer music servers, crossovers, and equalization |
I am looking to build a sound system from a used PC (Windows Vista OS).
I have an AudioSource AMP-100 Stereo Power Amplifier, ADC SS100-SL 10 band Graphic EQ, and a decent set of Harvard 3 way speakers. and some exterior rock speakers for around the pool. Question 1, can i incorporate the EQ into my set up? I would much rather use it and not the eq on the PC if at all possible. Question 2, do i need a converter for my PC line out? I believe its analog output from the green line out. The soundcard also has an orange digital out from what i understand based on the line out color codes ive found online. Question 3, do i need a ground loop isolator? will i get a lot of hum through the amp using a pc as the source? Thanks, Joonze |
#2 |
1) Yes
2) It depends on the quality of the on-board sound. Sometimes you can here every hard drive access or movement of the mouse, due to poor design of the on-board sound stuff. An outboard digital to analog converter (DAC) (under $20 shipped on eBay) should be a vast improvement. Or try a ridiculously cheap "Music Fairy" (ebay) USB sound device. 3) If hum is a problem, I'd use the digital out and a DAC. If neither the digital output or the DAC have isolation, make a 1:1 transformer using ferrite beads or the transformer from an old ethernet card or hub. |
#3 |
Thanks alot....
will one of these work well? MUSE 24Bit/192Khz Digital Optical Coaxial to Analog RCA Audio Converter DAC B they are 21$ on ebay.... |
#4 |
I can recommend a Fiio D3 DAC as being a cheap way to convert from SPDIF to 2 ch stereo.
Works real nice.
Epoxy Resin fixes everything!
#5 |
I expect the MUSE DAC will be better than most on-board audio. I recommend you buy one, if only to share with everyone else here what chips are inside it. I've ordered one of the cheaper black box DACs from eBay (along with an ADC).
#6 |
Before you spend any money on hardware, get rid of Vista and upgrade to Windows 7.
All sound processing, etc will be better, easier, less buggy.
I was so much older then, I'm younger than that now. |
#7 |
Because this pc is just a flac player for me, i cant justify the windows upgrade. would there really be a big difference in the sound processing? I guess to can compare by connecting my windows 7 laptop and seeing if a hear anything different...is there any kinda documentation that i could read that compares the two OS for this scenario?
#8 |
If there are sound differences between your pc & laptop, it's most likely due to the hardware and not vista or 7. When both are set up properly there should be no difference, but linux is better because it's very easy to slim it down to do just what you want: play music...
-- Sent from my Palm Veer using Forums |
| ANN: HpW Works V3.0 PC based Measurement System | HpW | Vendor's Bazaar | 1 | 25th October 2012 11:47 AM |
| So I want my PC hooked up to my system, newby questions. | gil1 | PC Based | 3 | 5th August 2011 01:17 AM |
| best PC based audio analyser | robmil | Equipment & Tools | 3 | 4th May 2011 05:46 PM |
| Need recommendation for a PC-based measuring system | andy2 | Multi-Way | 10 | 23rd December 2006 10:27 AM |
| a new system based on Fullrangers- PC or CD player | T11 | Digital Source | 4 | 6th October 2006 02:43 PM |
