Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 13th April 2012, 02:42 AM   #1
_henry_ is offline _henry_  Australia
Default motu 828mk2 on pure music problem
hi,
i like to implement digital XO using MOTU 828mk2 w/ pure music on Macosx.
i have trouble getting the output in puremusic, there's no output coming out from it.cx
iTunes is ok though through the main output of motu.
MOTU have 2 main output (L&R) and 8 analog output.
At first i didnt set the AUDIO MIDI SETUP, since pure music i believe can identify the output, after unsuccessful try finally i went to AUDIO MIDI SETUP to set the motu as audio output, with 8 analog out.
it is still without ouput on pure music.
anyone have experience setting up an audio interface with pure music?
cheers
henry
Old 17th April 2012, 04:24 AM   #2
ok, the channel D support is excellent, finally ive emailed them about it with the screen caps of my settings, they replied me just within 2hrs.
for FLAC files we need to use MEMORY PLAY.
then... there's another problem, it only works flawlessly on the MAIN OUTPUT of the MOTU.
when i select Output 3&4, ALL 8 outputs are live and all outputs give the same distorted sound which is like surpress crackling music.
anyone can help???
cheers
henry
Old 18th April 2012, 03:05 PM   #3
Again great support from channel D.
Rob just help me with Remote Connection using Team Viewer to fix the problem.
its basically just to tick a box of secondary stream from Motu traveler, dont know why it works, but it does
cheers to Rob
henry
New problem with Music Angel KT88 alecu7 Tubes / Valves 31 17th August 2012 08:15 PM
XO using MOTU 828mk3 hybrid shumgary Digital Line Level 28 13th April 2012 06:22 AM
MOTU Ultralite Hybrid mod jhoffm34 Digital Source 0 22nd September 2011 02:28 AM
"Pure Music" software discussion thread dvb-projekt PC Based 62 3rd June 2011 04:53 PM
Motu mk1 issue please heeeelp!!! ChristianFP Digital Source 1 6th August 2009 01:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright Đ1999-2013 diyAudio
