Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 20th March 2012, 08:00 PM   #1
merlin el mago's Avatar
Default External HDD
I'm looking for HDD 1TB or more for my Sony VAIO laptop of course is for audio so fanless but very good quality & minimum USB2.0 or Fireware.
Help will welcome, thanks.
Felipe
Old 20th March 2012, 10:02 PM   #2
Wombat is offline Wombat  Germany
Wombat's Avatar
For use with a Laptop iŽd suggest one of the recent 2.5" drives.
I use a 2.5" Saegate GoFlex atm and canŽt exactly hear it spinning when it lays in front of me. It gets its power solely from the USB port. They offer a Firerwire connector for the GoFlex models also.
Since we talk about our beloved audio data you may wonder about longer warranty or MTBF times. So a 3.5" may give you more safety as the smaller 2.5" drives. Since nonetheless you should at least have one backup this may not matter to you.
For 3.5" drives you also may consider it needs another PSU that may under some circumstances influence other equipment when you power several pieces of your audiochain from one power plug.
If time permits - stuff some parsley in your ears and listen how it grows!
Old 20th March 2012, 10:22 PM   #3
Thanks Wombat, what kind of connection between my Sony Vaio & HDD is better: Firewire or USB2.0?
Old 20th March 2012, 10:35 PM   #4
Wombat's Avatar
Good question. Speed wise the drive is faster as the maximum of USB2.0 i guess. I use mine with USB 3.0 and it can reach up to ~45MB/s while i remember to have around a maximum of ~28MB/s with USB 2.0 drives. This is some real world experience i have with my hardware, others may vary.
Since i did read about several badly implemented USB 2.0 ports in older hardware Firewire may be faster with your Laptop but this is only a guess.
Edit: here is an overview of the theoretical speeds of different interfaces: http://en.wikipedia.org/wiki/List_of...tes#Peripheral
Like mentioned the implementation of specific harware inside the Laptop and the drive itself may vary these speeds a lot.
Old 20th March 2012, 10:54 PM   #5
Thanks again.
Old 20th March 2012, 11:40 PM   #6
cocolino's Avatar
I found that Firewire in practice (although theoretically it shouldn`t) usually is a tad faster than USB 2.0 (10% to 20%) + in case Your VAIO is an "older" model Firewire likely has less compatibility issues.
I had quite some trouble with USB 2.0 driver issues with older hardware (about before 2005 or so).
There are external HD enclosures that have both USB-2 and Firewire.
Christoph
STEAL the BEST - INVENT the REST
Old 21st March 2012, 12:34 AM   #7
I have two Samsung Story Station 3's, one for music and one for video.
Two GB, USB 3 capability but backwards compatible.
I have had no issues with them and they are reasonably priced.
Old 21st March 2012, 01:21 AM   #8
infinia is offline infinia  United States
infinia's Avatar
>1TB means 3.5 drives inside. I have an 320GB HDD external enclosure with both firewire and USB. It seems much faster indexing the contents on a Windows PC using USB, I assume it would be the reverse on an Apple. Larger video files maybe better on firewire. Shop for an enclosure with both interfaces and roll yer own.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 21st March 2012, 01:24 AM   #9
Wombat's Avatar
No, Seagate GoFlex 2.5" goes up to 1.5TB.
Old 21st March 2012, 01:29 AM   #10
Sorry, misprint.
Should have been 2TB each.
external HDD player, with touchscreen and digital out anm Parts 16 21st October 2010 07:41 AM
HDD to I2s interface elnec Digital Line Level 6 15th September 2008 08:43 PM
CD to HDD AndrewT Digital Source 14 27th July 2008 09:02 AM
adding second HDD to PC AndrewT Everything Else 80 5th December 2007 01:38 PM
Adding a second HDD to a laptop Simpleton Everything Else 27 25th June 2006 06:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
