How powerfull does a PC have to be - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 8th March 2012, 10:05 PM   #1
Default How powerfull does a PC have to be
I am putting together my first music server, running JRiver 17. I will be running 192 / 32 out of it. I need some advice on how fast a processor and how much memory I need. Any advice on keeping it quiet is helpful as well. I did not find any good thread when I searched. Thanks
Old 8th March 2012, 10:09 PM   #2
parb is offline parb  United States
i doubt you need very much. the forums for video says you can run this software with video encoders on a core i3. memory wise 2GB of ram is cheap and doesnt create much heat.
this place is great for getting input on component selection for silent computers:
silentpcreview.com | Everything about Silent / Quiet Computers
Old 9th March 2012, 02:38 PM   #3
Once upon a time I had a blue&white Mac featuring a 350MHz processor with 637Mb of memory.
I had no problems running 16 channels of 24/96 audio simultaneously.
Old 9th March 2012, 02:46 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I have an old AM486 running DOS 7.10, and MPXPLAY159. This is sufficient. And donīt has blue screens !!!
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 9th March 2012, 02:54 PM   #5
KatieandDad's Avatar
As powerful and modern as you can afford.
If you look at the prices of the latest i9 then the lesser i7, i5, i3 and on down towards Q6600 and lower, you will notice that there is a definite price "knee".
Although the lower processor will certainly do the job you may struggle to get motherboard and peripherals to work with it. Manufacturers like to con us into continuing to buy "new".
So like I said. Rolls Royce may be far too expensive but why buy a Talbot Horizon when you can get a mid ranger for reasonable money.
The boy next door (Flea-Bay) is a good place to pick up yesterdays computers from guys that just have to have the latest and best computer.
Old 10th March 2012, 01:19 AM   #6
5th element's Avatar
I agree 100% with what KatieandDad has said above me, at least when it comes to buying a PC with performance in mind at a semi reasonable price. The fastest stuff, or close to and top tier of PC parts always cost significantly more then their lower spec'd (read the last quaters) top performers. As K&D mentions there is always a knee in the prices where they jump up significantly for that last 5-10% in performance.
Of course this isn't what you were asking mind you, but streaming audio doesn't typically use that much processing power, any of the cheap modern processors will be more then enough. Streaming high quality compressed video on the other hand can use quite a bit, but any decent modern processor, once again, should be more then up to the task.
Memory is more of an operating system issue. You can of course use full file buffering for playback, where the entire track is loaded into RAM before the file is played, but most audio files tend to be quite small.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 10th March 2012, 10:10 AM   #7
marce is offline marce  United Kingdom
I will also agree with the last two posts.
At the moment I use a Compaq E-400 with 1.5Tb disk, when used with a single squeezebox, no problem, but when everyone else wants to link up with Xboxes, DVD players etc, it soon goes down hill. I am going to get a proper server set up when i can afford, to control my media. I did read a recomendation that said one core and 2GB of memory per user...I cant confirm as I am new to PC based media.
Old 14th March 2012, 07:29 PM   #8
PB2 is offline PB2  United States
PB2's Avatar
Are you planning to do video from it also?
Old 14th March 2012, 10:03 PM   #9
TheGimp is offline TheGimp  United States
TheGimp's Avatar
My son is running a 4 year old Atom ITX and it does video and audio fine. That said, watch out for the ITX running i-series processors.
I was waiting for the D2700-ITX to come out but gave up on it after doing a bunch of research and went with a small case standard mini-ATX system. The D2700 ITX with an i3 or i5, would have required a fan any way, and the power supply would have had a fan, so no fanless system.
You can go fanless if you go with an Atom processor.
Old 15th March 2012, 10:05 PM   #10
I'm running ..
Intel Core i3-2120T 35W $135
Sythe Ninja 3 cooler $40, fanless
ITX motherboard $85
8GB memory $40
PicoPSU-150-XT $70, fanless
SSD 120GB was $200
cheap case $50, side opened
around $600 + Win7.
That Looks Powerfull !!!! east electronics Solid State 4 25th February 2008 09:10 PM
Spuddo more powerfull Jaime Tubes / Valves 11 19th August 2007 08:56 PM
powerfull schematic east electronics Solid State 23 24th July 2007 12:49 PM
Powerfull 5.1. Dxvideo Chip Amps 12 9th December 2003 08:52 PM
Copyright Đ1999-2017 diyAudio
