| PC Based Computer music servers, crossovers, and equalization |
#31 | ||
The point is that if the supplies and the surrounding decoupling and layout were insufficient then you would see this in the measurements. Quote:
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#32 | |
#33 |
Qusp, it was just to show the one of the new packaging styles for mosfets, IR have some very interesting packages as well, it was nothing to do with the electrical specifications. Over the last decade component packaging has evolved, pushed by the requirements for more in less space, and the requirement to get the heat away from the actual chip. The new packaging is designed to reduce the junction to case thermal resistance allowing for more efficient removal of heat from the die. One of my favorite MosFet packages is this:
http://www.irf.com/technical-info/appnotes/an-1035.pdf With the right design with a metal case you can arrange the layout so that the case becomes the heatsink, much easier for automated production than TO-220s. With a digital to analogue system and the right equipement you can feed a controlled set of step frequencies and automaticly monitor the waveform, and also a controlled mix of frequencies, often done when CS101 tests have to be carried out. |
#34 | |
#35 | |
Now electronic devices do show resonance issues with high speed circuits, but this occurs at very high frequencies, much higher then you're ever going to encounter within audio work. Of course you could purposefully design in resonances within the audio band using certain filters, but why would you want to do that? And on top of that you'd be aware of it as you put it there in the first place.
#36 | |
#37 |
If the complex passages are band-limited to fs/2, then fourier holds no matter how complex they are.
#38 |
I'm sure this thread will spiral into tangential inanity regardless, but the important mod to be done on the ST/X cards is replacing the clock - Vanguards are available on ebay. It is a substantial increase in sound quality. This has been covered elsewhere on the web with a lot of positive feedback.
From what I have read elsewhere, power supply mods are not as beneficial. Last edited by wushuliu; 5th March 2012 at 07:18 PM. |
#39 |
Any real proof! or just listening?
#40 |
Listening. It's very evident. Nothing subtle about it.
| Gigawork DAC vs Asus xonar essence stx | robump | PC Based | 13 | 8th April 2011 07:01 AM |
| New Asus Xonar Essence STX Drivers | Brian Kingsbury | PC Based | 6 | 9th March 2011 09:52 AM |
| I2s from asus essence stx? | bambadoo | Digital Line Level | 1 | 19th February 2011 01:05 AM |
| Issues Of Asus Xonar Essence Stx | fotios | Digital Line Level | 0 | 12th May 2009 09:42 PM |
| Asus Xonar Essence STX analog input? | fotios | Digital Line Level | 1 | 25th April 2009 10:55 PM |
