Small cheap USB DAC, any recommendation? - diyAudio
Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 14th February 2012, 06:44 PM   #1
Franfj is offline Franfj  Spain
Default Small cheap USB DAC, any recommendation?
I am looking for a small cheap DAC, what I'm planning to do is to fix it in a small TA2020 Amp to hopefully avoid the high noise coming from my Macbook Pro Jack Socket.
What I need is USB connectivity (no need of optical or coaxial inputs), low price (about 10€ will be fine, I don't plan spending more than the cost of the amp in the DAC)…
I have had a look and found cheap DACs based on PCM2704 like this
http://www.ebay.es/itm/MINI-PCM2704-...0#ht_573wt_970
Opinions about them? Any other better option for that price?
I hope that using a separate DAC instead the Macbook jack output will reduce the noise that it produces…
Old 28th February 2012, 06:05 PM   #2
In my experience with computers and sound, if your problem is a ground loop, sometimes even having a cheap usb dac (particularly one powered by the USB bus), won't eliminate noise.
You may instead want to try a good ground loop isolator. Parts express has one that has been measured to have flat response from 20-20khz. Other good ones exist on Amazon, etc. You can make one using 1:1 transformers, if you wish.
edit: if you unplug your macbook from the power supply, and the noise substantially diminishes or disappears, you can almost certainly fix this with a $10 isolator.
Last edited by neebster; 28th February 2012 at 06:08 PM. Reason: Left out a detail, don't want to overpost
Old 28th February 2012, 06:40 PM   #3
Thanks for the reply
Mmm, with the Macbook unpluged I get the same noise (even with headphones and the macbook unpluged is audible) so I think that is not a ground loop problem (and is not like a 50hz humm, is more like a med-high frequency white noise).
Considering that, do you think that using an external DAC will improve sound?
Old 28th February 2012, 06:57 PM   #4
Hi!
I have the same problem with the analog-stereo-output on my old (but beloved) IBM TP T22. It's this "white-noise" kind of sound, which has nothing to do with a ground loop. An isolation transformer would not help. I would recommend buying a nice USB-DAC, or, try to use a volume pot between the stereo-output and your amp. At moderate to even high volumes the noise-level is hardly notable. Only without a pot (when adjusting volume only via the digital notebook volume control) the noise is always there, regardless of the digital volume level.
For USB-DACs: I really recommend the KingRex UD-01. Even the stock version sounds quite sophisticated. To go for something really inexpensive might not be a long term solution.
Regards - Martin
Old 28th February 2012, 07:36 PM   #5
jrenkin is offline jrenkin  United States
Try the twisted pear USB converter, it is designed to output SPDIF or IS2, but has a quite acceptable DAC chip for analog output, too. It would be a flexible option in the future.
Old 28th February 2012, 08:37 PM   #6
Check out this site:
NwAvGuy
First rate information on inexpensive USB DAC's.
Old 28th February 2012, 10:57 PM   #7
Without an OpAmp on the output, it will behive very badly on any low impedance (like headphones). I don't think your amplifier input impedance is too high either.
"Naked" PCM 2704 is garbage IMO.
Old 28th February 2012, 11:55 PM   #8
Looks interesting. The other models mentioned are out of my possibilities at the moment.
I will try to increase the what I could pay for something like this and try to get other options...
Any "good" USB DAC + Headphone AMP under 60$?
USB DAC recommendation currentflow PC Based 24 7th February 2012 05:23 PM
USB DAC recommendation lost eden Digital Line Level 0 11th January 2012 02:14 PM
WTB Cheap USB DAC preferably UK or EU valleyman Swap Meet 9 8th September 2009 06:37 AM
Cheap "USB DAC" M-Audio Transit + Marantz CD60 lucpes Digital Source 10 11th February 2009 10:34 AM
Hacking a cheap-0 USB DAC. (Or, helping a cheapass get better sound.) Spasticteapot Digital Source 5 15th December 2006 01:32 PM
Copyright ©1999-2017 diyAudio
