Go Back   Home > Forums > Source & Line > PC Based
PC Based Computer music servers, crossovers, and equalization
Old 15th January 2012, 04:26 PM   #1
bmk352 is offline bmk352  United States
Default Multi-Room/Multi-Zone Audio Setup
I have been searching around and trying to figure out the best way to create a multi-room multi-zoned setup on the relatively inexpensive side. This rules out a Sonos or Squeezebox based solution as they are both too expensive to implement.
Currently I am looking at using an alix3d3 PC Engines alix3d3 product file board as it supports POE and has an stereo audio output removing the need for at least one power plug at the output source.
Ideally what I would like to be able to accomplish with this system is have 3 zones run by a board a piece pulling my music from my linux server. With these 3 zones I would like to be able to either play a different song in each zone or have a single song synced among the zones akin to Sonos.
I have played with MPD (music player daemon) which installs easily using the voyager-mpd linux install and works well for a single output at a time, but not multiple zones as far as I can tell.
Has anyone been able to accomplish something like this and are there instructions for diy?
Old 17th January 2012, 10:22 AM   #2
Send a message via MSN to egberttheone
What about cobranet ?
I bought 10 of these Network Audio Processor PRN NAP CobraNet | eBay
they have build in class d amps, inputs, outputs.
Works on 12V
Old 17th January 2012, 11:23 AM   #3
DO you have any more information on those boxes? How are you driving them? A quick google didnt find much.
Jonathan
Old 17th January 2012, 11:47 AM   #4
Well after a little bit of playing over the last couple of days I believe I am going to try Squeezebox server driving the aforementioned hardware components with Squeezeslave. A few tests with a laptop running Voyager-linux with a freshly compiled Squeezeslave instance and the windows client running on my main pc and I think I am sold on how things are working as well as how to control them via android or iphone. The only quirk I have found thus far is that the only place I can set them to synchronized play is from the server webpage and not from the phone (android).
Old 23rd January 2012, 10:07 AM   #5
I do have some information but as i want to sell my 10 pieces i'm not going to give it here in public i'm sorry.
Old 24th January 2012, 08:35 PM   #6
von.ah is offline von.ah  United States
von.ah's Avatar
bmk352, that looks like a very slick way of putting together a networked audio system on a small(er) budget. Kudos.
I look forward to seeing your progress.
Old 4th February 2012, 10:43 PM   #7
Well here's what I have ended up doing:
Spun up a VM on my ESX server and installed Ubuntu Server 10.04 x64 base install and updates.
Installed Logitech Media Server using repository instructions Debian Package - SqueezeboxWiki
Installed Voyage Linux on a spare laptop and compiled Squeezeslave from source SqueezeSlave - SqueezeboxWiki
Installed Voyage Linux on CF Card and setup Alix hardware
for use with X (alix3d3/alix1d):
changes in "/etc/inittab":
comment "T0:23:respawn:/sbin/getty –L ttyS0"
uncomment "#1:2345:respawn:/sbin/getty –L tty1"
changes in "/boot/grub/menu.lst":
"terminal serial" replace with "terminal console"
"kernel … console=ttyS0" replace with "… console=tty0"
comment "serial --speed=38400"
Copied compiled Squeezeslave from spare laptop to Alix hardware CF card and setup an automated startup daemon script.
Now I am running the Alix Squeezeslave over POE and have some speakers hooked up to the analog audio output.
With this hardware I have the option of adding a display later in case I want to have something shown
as well as adding a high quality USB DAC at a later date.
And the materials:
$130.60 Shipped ALIX 3d3 System board alix3d3
$11.85 Shipped 18V DC Adapter 18V DC Power Adapter (1A Output, 100-240V AC Input, 2.1mm ID / 5.5mm OD) - PI Manufacturing Corp.
$15.99 Shipped Sandisk Ultra 4GB CF Card http://www.amazon.com/gp/product/B00...00_i00_details
$3.99 Power Over Ethernet Injector POE
$12.50 Indoor enclosure for ALIX.3 Boards box2c
$0.98 I/O Bracket for Alix.3D3 I/O Bracket for Alix.3D3
$2.75 Shipping
$178.66 Total Cost
Old 1st April 2012, 02:03 AM   #8
ALIX 3d3 $125
CF 4Gig
POEP $3.5
Enclosure ALIX.3 with bracket
Old 1st April 2012, 03:38 AM   #9
I'm waiting on Raspberry Pi for the same thing.
Russound CAM6.6 Multi Zone Controller 503Timber Swap Meet 0 10th July 2011 06:11 AM
multi zone speaker hookup willlgord Multi-Way 0 13th December 2010 01:32 PM
Multi zone setup with ATI 6012 neil_kaye Solid State 2 30th September 2010 04:26 AM
Input stage for multi-zone amp. wsmckenz Class D 2 2nd February 2010 11:45 PM
Amps for Whole House Audio : Multi-Room : Muilt-Zone Livin Class D 5 5th January 2008 06:59 PM
Page generated in 0.09881 seconds (80.92% PHP - 19.08% MySQL) with 10 queries
