PC Based Computer music servers, crossovers, and equalization
Rasberry Pi and active crossover revolution
Old 12th February 2013, 05:44 PM   #71
qingcai is offline qingcai  United States
The DACs are equivalent to 11 bit cf 16 for CD.
Old 12th February 2013, 05:48 PM   #72
Bluetooth 3.0+HS provides theoretical data transfer speeds of up to 24 Mbit/s
how wide do you need?
Originally Posted by planet10 View Post
Bluetooth doesn't have the bandwidth for decent fidelity
dave
Old 24th February 2013, 12:06 AM   #73
mcluxun is offline mcluxun  United States
today I put squeezeslave on RPi.
Now it works as a squeezebox.
Old 2nd February 2015, 09:09 PM   #74
jesushatesjunkmail is offline jesushatesjunkmail  United States
The new Raspberry Pi 2 is out. Still $35. Six times faster.
Old 10th February 2015, 10:32 AM   #75
skyunlimited is offline skyunlimited  Germany
It is out and it is running Brutefir perfectly. I have a 3 Way Stereo convolver running with Cpu load of 25 % on 2 Cores using a Logilink UA0099.
Old 11th February 2015, 09:42 AM   #76
LucasValderrama is offline LucasValderrama  Spain
Hi skyunlimited! Any other clues for a newbie? Do you use the standard distro?
Old 12th February 2015, 06:36 AM   #77
As Basement I took a "Stock-Raspbian" and compiled MPD with Pipe-out so MPD is feeding Brutefir via PipeOut (Pipe-out is disabled by default on MPD so you have to build it from source).
Although there are Instructions all over the Internet, how to set up MPD and Brutefir, you will need some Linux Experience to get Things working.
Old 30th December 2015, 10:36 PM   #78
keylimesoda is offline keylimesoda  United States
FYI, for folks looking into doing DRC (using FIR filters) on RPi devices.
RPi2: BruteFIR uses the FFTW library for most of its heavy lifting. The most recent FFTW engine utilizes ARM7's SIMD instruction set (called NEON). Bottom line, BruteFIR on RPi2 should run reasonably efficient.
RPi: Since there's no NEON instructions on the RPi, you have to find a different way to optimize. Thankfully, someone figured out how to do limited FFT calculations using the RPi GPU. And even cooler, someone else figure out how a hack to replace the FFTW libraries with the faster GPU_FFT libraries on an RPi: https://github.com/gpu-fftw/gpu_fftw. I've not seen anyone put this together end-to-end with BruteFIR yet, but this is probably the best chance for high-speed convolution on an RPi.
Old 1st January 2016, 02:01 AM   #79
AEDIO_Japan is offline AEDIO_Japan  Japan
Default I am using multi-channel outputs on Raspi2 and HDMI for active crossover
Some of you knows of me as provider of Windows based FIR plugin through Down load from file
Recently one Japanese audiophile developed FIR filter based on BruteFIR / mpd / HDMI interface. And prized at Magazine Nikkei Computer Raspberry PI technical competition.
Though it is not implemented on standard HDMI audio driver software, it worked well.
(1) Audio data on mpd (rapbian jessie) is converted to 96kHz / 32 bit x 2channel pipe output by mpd "format "96000:32:2".
This simplified sample rate conversion difficulties.
(2) FIR filter parameters are generated by "octave-signal" (MAT-LAB clone?).
to meet with BruteFIR library requirements.
(3) This can be 3way FIR filter and 4way FIR filter switched by "octave-signal" macros.
If you have volumio compliant multi-channel DAC , you can map 6 or 8 channels by "aplay" command, you can use your DAC using "aplay".
Prerequisite:
(a) Raspberry Pi2 (almost upto 70% of CPU Power consumption)
(b) Raspbian Jessie light or similar.
(c) HDMI multi-channel AV amplifier that can be used as Multi-channel Linear PCM D/A converter. We have tested on Marantz NR-1501 and Newer Yamaha ones.
But on older SONY TA-DA3200ES cannot be used though it can be used on Windows, I guess SONY was too older specification not compliant new HDMI specs.
(d) Speaker system for test
I have used Woofer Audio Technology 10C77 KAP in 56littre,Mid: Accuton C50-8-044 50mm Ceramic and Scan-Speak D3004-6640-00 Beryllium dome.
When played with this speaker the audience (almost demo is for 20 persons) commented below,
"The amplifier NR1501 is NOT powerful so lower section was sounds NOT powerful. But we felt Raspberry Pi2 and HDMI active crossover system opened NEWER HORIZON for those who like PC audio and high-end audio system.If we can have next demo, we like to listen to newer powerful amplifiers , especially low woofer amp."
This software archtecture can be used on Normal intel mpd/linux(such as Ubuntu Studio 64bit or similar).
If you are intereested in this system,please send me e-mail.
Yutaka IIDA,CTO,AEDIO Japan ,Tokyo,Japan
Old 1st January 2016, 04:04 AM   #80
Default How to setup and install active crossover on Raspberry Pi2/HDMI
[Note]:You donot have to set memory split value lower.
If you set the value 16 you cannot output audio output through HDMI.
Preparations:
(1) Reboot and update:
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
Then reboot
(2) Install required software
sudo apt-get install libfftw3-dev mpd
(3) Install hdmi_play2.bin
cd /opt/vc/src/hello_pi
./rebuild.sh
cd
Download and expand :
http://audio2.amanogawa.info/public/..._v0.11_.tar.gz
cd
tar xvf hdmi_play2.tar.gz
cd hdmi_play2
make
sudo cp hdmi_play2.bin /usr/bin/
(4) Download and expand FIR filter modules
http://audio2.amanogawa.info/public/..._v0.12_.tar.gz
cd
tar xvf amafir.tar.gz
cd amafir_src
make
sudo cp amafir /usr/bin/
Then edit /etc/fstab
(5) setup /etc/mpd.conf
You have to backup current /etc/mpd.conf such as "sudo cp /etc/mpd.conf /etc/mpd.conf.old"
/etc/mpd.conf output section , you have to add,
audio_out {
type "pipe"
name "amafir"
command "amafir /home/pi/amafir | hdmi_play2.bin 96000"
# command "amafir /home/pi/amafir | nice -n -20 hdmi_play2.bin 96000"
format "96000:32:2"
Rasberry Pi and active crossover revolutionHide this!Advertise here!
Tractrix in 1*Pi and 2*Pi revintage Multi-Way 21 26th August 2011 09:37 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Active Crossover soundNERD Chip Amps 5 24th September 2003 01:39 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
